p mag tach hookup to rmi
how did you do this? I am installing 1 p mag for now. Will it work the way it is now with the pulse coming off of the p lead ? Or do I have to remove this setup and use the tach output from the p mag and install the diode or just go direct from the p mag. Thanks
