Old 08-23-2006, 11:24 AM
RV7Factory's Avatar
RV7Factory RV7Factory is offline
Chief Obfuscation Officer
Default Capacitive Sender Question
I will try to keep this short...
Does anybody think that the tail of a pop-rivet sticking ~1/8" into the 3/8" space between the rib and capacitive sender plate will interfere or cause the sender readings to be thrown off?
I am inclined to think "no", but since this is tank related I would like to feel a little more confident before I seal it up (again).
Thanks!
Brad Oliver
Livermore, CA | RV-7 | SOLD
RV-7: RV7Factory.com | iPhone app list: AviatorApps.com | Photography: BradOliver.com
Old 08-23-2006, 11:26 AM
Captain_John's Avatar
Brad, I am thinking no as well.
What did you rivet there that has a pop rivet in it anyways?
CJ
The experiment works!
Old 08-23-2006, 11:36 AM
painless painless is offline
So long as it does not contact the capacitance plate, there should be no problem. Once the plates are secured in place, they shouldn't vibrate and cause intermitant contact with the rivet in question.
I too am curious why you have a pulled rivet in there....
Regards,
Jeff Orear
RV6A N782P
Peshtigo, WI
RV7Factory's Avatar
I forgot the anti-hang-up angle for the flopper...D'oh! Full story here.
I tried angling it back away from the cap sender area, but I didn't like how the flop tube hit it (could be asking for trouble).
Brad Oliver
Old 08-23-2006, 11:40 AM
Chickenlips Chickenlips is offline
I am pretty sure the capacitive system relies on both surface area of the plates as well as spacing to the ribs. So, having a pop rivet head in an area will have some "tiny" effect... but if you look at the overall area then it will be insignificant. IMHO
Old 08-23-2006, 11:48 AM
What a name....Chickenlips!!! LOL
Anyway....I am not so sure the spacing from the ribs is a factor. The major factor is that the plates are isolated from the rest of the tank electrically. The distance between the plates is another factor, but again this rivet is a non issue in that regard.
Jeff Orear
RV6A N782P
Peshtigo, WI
Old 08-23-2006, 12:08 PM
thallock thallock is offline
Actually, the spacing from the ribs does matter, because that is how a capacitor works. Plates closer together, more capacitance, further appart, less. However, the surface area of the rivet is so small that it should have a minimal effect on how the sender performs.
Tracy.
Tracy Hallock
Austin, Tx
RV-7(EH) - Fuselage
http://www.trv7.com
Old 08-23-2006, 12:10 PM
RV7Factory's Avatar
I had the same reaction.
Thanks for the input guys! I haven't put the rivet in yet, I stopped just short of it when it occured to me where the tail of the rivet would be. Maybe I should just put a pop-rivet in the same place in the other tank so that they are "off" by the same amount.
Brad Oliver
Old 08-23-2006, 12:36 PM
Brad, I really don't think you have anything to worry about. It is worth checking in to, though.
I think that once the system is calibrated you are set.
CJ
Old 08-23-2006, 12:58 PM
Guy Prevost's Avatar
Guy Prevost Guy Prevost is offline
You calibrate the system yourself. Any errors cause by the rivet will be in the noise anyway.
G
Guy Prevost
Albuquerque, NM
RV-8a Built, Enjoyed, Sold
Two Kids: Built, Enjoying
RV-10, Bought, Rebuilt, Enjoying
Build / First Flight Video: http://www.youtube.com/watch?v=8f9HXzZT1dE
Build Log: http://websites.expercraft.com/geprevo/
Arguing on the internet is like having a competition to see who can hit a brick wall the hardest. You may win, but you're still an idiot.
