Old 08-12-2013, 09:07 AM
kinger's Avatar
kinger kinger is offline
Default FAA Continental Cylinder proposed AD
The FAA proposed an Airworthiness Directive (AD) to limit the allowable time-in-service of more than 30,000 TITAN brand 520- and 550-series cylinder assemblies installed on about 6,000 Continental IO-520, TSIO-520, IO-550 and IOF-550 engines.
http://www.aviationpros.com/news/111...ers-83-million
James King
RV-7
919
Old 08-13-2013, 10:35 AM
grub0927 grub0927 is offline
Default AD on Continental 520/550 cylinders
Eliminate a PMA'r and the OEM raise prices. This can't be good for GA.
Old 08-13-2013, 11:46 AM
DanH's Avatar
DanH DanH is online now
ECI is offering very good arguments as to why the AD is unnecessary and counterproductive. If you agree file a comment with the FAA.
[ed. I believe this link will work for comments on line]
Dan Horton
RV-8 SS
Barrett IO-390
Old 08-13-2013, 12:00 PM
Buggsy2's Avatar
Buggsy2 Buggsy2 is offline
Few if any of these engines are used in RVs, right? What engine does Vans recommend for the RV-10 and -14?
The article cited is interesting, I'd like to see the FAA's side of it. But, with a Lyc IO-320 in my RV-9A, I probably won't bother
Ralph Finch
RV-9A QB-SA
Davis, CA
Old 08-13-2013, 11:26 PM
grayforge's Avatar
grayforge grayforge is offline
I don't think there are many Continentals in RV's :-)
Speed Is Life
VAF Donation made: 1/28/2020, My RV-7A Build Log
Old 08-13-2013, 11:44 PM
SHIPCHIEF SHIPCHIEF is offline
Continental today, Lycoming tomorrow. Don't hold back on commenting, cylinders have not previously been time limited parts. Once removed from an engine they are judged by their condition. This starts a whole new beaurocratic nightmare that needs to be stopped right now.
Mike Busch (sp?) has pointed out some statistical anomalies in previous cylinder failure ADs that wouldn't pass with current research. Severly abused products that failed should not be used as proof of manufacturers defect. Also, aftermarket parts that fail at a lower statistical rate that OEM equipment are being AD'd here.
Improved condition inspection during servicing or rebuilding is a much better path to improved service.
Scott Emery
http://gallery.eaa326.org/v/members/semery/
EAA 668340, chapter 326 & IAC chapter 67
RV-8 N89SE first flight 12/26/2013
Yak55M, and the wife has an RV-4
There is nothing-absolute nothing-half so much worth doing as simply messing around with Aeroplanes
(with apologies to Ratty)
2019
Old 08-14-2013, 06:41 AM
gereed75 gereed75 is offline
Please make comments to FAA. It is easy to do. Take some time to get educated (I suggest starting here http://www.vansairforce.com/communit...ight=cylinders ) Form an educated opinion. Make a comment. It's important!
ECI is at the forefront of cylinder development. Don't believe me? Go read their website. They have done a lot of good engineering from which we all benefit whether you have a Continental or a Lyc.
Who knows if they can survive another heavy handed recall. We do not want to lose suppliers in this already too small industry.
Gary Reed
RV-6 IO-360
WW 200 RV now an Al Hartzell for improved CG
Old 08-22-2013, 07:54 PM
Tom Horne Tom Horne is offline
Default Please comment
Search Google for 'ECI NPRM'. There you can find the links to all the data. If you read the comments and the materials presented it's hard to see why this
AD is supported by solid data. I agree totally that we in the aviation community need to stick together in this era of more government influences regardless of whether it's a Lyc or Continental. What may even be scarier is that Continental and Superior are now owned by the Chinese. The only remaining source for US Continental style cylinder parts is ECI. I think they're doing a great job and hate to see the cost, reduction in safety, and possibly reduction in suppliers with this AD that I feel is not justified by the data presented.
Tom Horne
Old 08-22-2013, 08:49 PM
BillL BillL is offline
I looked at several of the links and did not find the projected failure rate of these components. I did not look at them all but did find the raw data. Has anyone seen a Weibull plot with confidence bands plotted for the raw failure data to see what we are really dealing with here? This would seem to be the proper way to assess the failure rate and "life" of the cylinders.
Bill
RV-7
Lord Kelvin:
Old 08-22-2013, 08:53 PM
rocketbob's Avatar
The FAA doesn't care about comments for AD NPRM's. Once their mind is made up to pursue an AD the NPRM process is nothing but that, a process. Last year there was an stabilator horn AD on my Comanche and many good common sense arguments were made against it, the FAA ignored them all with terse responses to each commenter along the lines of no data to support your claims.
Bob Japundza CFI A&PIA
N678X F1 Rocket, under const.
N8155F C150 flying
Not a thing I own is stock.
