Old 08-11-2013, 08:29 PM
comfortcat's Avatar
comfortcat comfortcat is offline
Default Fuel pump for O-320 carbed engine...
I need to get a new mechanical fuel pump for my engine.
There seems to be two kinds of fuel pumps for the O-320. I have an E2D
ACS talks about new style and old. My rocker arm is riveted.
Do I need the riveted arm or can I get the "Channeled" arm?
CC
David Boeshaar
RV-9A - N18TD (reserved) - Fuselage.
"My greatest fear: What if the hokey pokey really IS what its all about?"
TDAircraft.com
-July-
Old 08-12-2013, 02:40 AM
newt's Avatar
newt newt is offline
Does your old one have a part number on it?
- mark
[ Paid up on 3 Feb 2020 ]
RV-6 VH-SOL
Old 08-12-2013, 07:25 AM
comfortcat's Avatar
Question Part Number...
Yes, the old pump has a part number, but the riveted arm is no longer available new. I wanted to know if the new model is different inside or outside. Do you have grief with the "new style" because of outside fit that is not an issue with the Van's ship.
CC
David Boeshaar
TDAircraft.com
-July-
Old 08-12-2013, 08:35 AM
659JR 659JR is offline
Default fuel pump
The pumps are interchangable between the new and old style and will fit the same. They will also take the same fittings and have the same pressure. All new pumps will have the channel arms.
Jesse
Old 08-15-2013, 10:47 AM
EagleEngines EagleEngines is offline
Default fuel pump
We have the AF15472 fuel pumps in-stock. The AF crosses to the LW15472 but is a little cheaper. The AF15472 is $304.21 and the LW15472 is $370. Let me know if I can help you.
Matt Brockman
Eagle Engines
530-221-4470
