Old 08-09-2013, 02:15 PM
mill2978's Avatar
mill2978 mill2978 is offline
Default Wire weight in the 8?
I am in the middle of my wings and about to order wire. I got this advertisement today from a company that caught my eye.
http://www.alliedelec.com/lp/130808b...130808_product
They claim this wire "meets or exceeds the electrical and thermal characteristics of PVC wire, while being smaller, lighter and more durable."
They are claiming that it is up to 40% lighter. How much weight in small gauge wire do you think is in a typical 7/8/9? Do I have to potential to save 10lbs or only a few ounces?
If it is ounces it probably isn't worth the time to explore further, but if it is lbs then I need to research the other items fire resistance, abrasion resistance,etc.
I tried searching the forums but didn't find much info for the total # of feet or wire weight in the average plane.
Aaron
Aaron Miller
RV8 N127KT - First Flight October 16, 2018
http://www.mykitlog.com/AaronMiller/
Old 08-09-2013, 02:30 PM
grayforge's Avatar
grayforge grayforge is offline
Is this new wire (and PVC wire) as good as aircraft grade Tefzel wire?
Speed Is Life
VAF Donation made: 1/28/2020, My RV-7A Build Log
Old 08-09-2013, 02:39 PM
bird's Avatar
bird bird is offline
PVC jacketed wire is very different than tefzel wire. The characteristic that I do not like about PVC wire is the fumes it emits when overheated. It is not as fuel and chemical resistant either. As far as weight, it would be difficult to to make much of a difference in our small aircraft. I would like to know the specs on this new wire, like what does it emit when overheated or if it comes in contact with other chemicals, uv, etc.
Bird
Bird
rv8 entire airframe at airport now, painting done, intersection and gear upper and lower fairings done, maybe order engine around first of year or before the next rate increase.
"to fly is a privilege that I am so thankful to God for"
http://www.mykitlog.com/tcb328/
Old 08-09-2013, 03:23 PM
mill2978's Avatar
Bird
Those are the same questions I have. The literature on the manufacturer site states "...because it is constructed of stranded tinned copper conductors and a Zero Halogen Polyphenylene Oxide (PPO) insulation that contains no halogens, phthalates or heavy metals. The absence of toxic materials means the product can be burned or disposed of safely without harm to people, animals or the environment."
I called them to ask about the chemical and abrasion details but it's Friday afternoon...I'll try again on Monday
Dupont has the spec for Tefzel here
Aaron Miller
Old 08-09-2013, 03:31 PM
bird's Avatar
Well tinned copper is very good so the weight savings must be in the insulation. It would be negligible in our planes though.
Brd
Bird
