Old 08-22-2006, 02:16 PM
prkaye prkaye is offline
Default air drill
My air drill seems to use a LOT of air. The 20-gal compressor comes on every 10 to 20 holes, depending. Is this normal?
When I pull the trigger on the drill, I can also feel air escaping out the back of it... is this normal??
Phil
RV9A (SB)
Flying since July 2010!
Ottawa, Canada
Old 08-22-2006, 02:32 PM
Robert M's Avatar
Robert M Robert M is offline
You betcha - drills use a lot of air. As I understand it, a 20 gallon tank is a touch on the small side for buiding an RV. You will still be able to build the plane its just that the compressor will run more often. I believe the recommended minimum size is 25 gallons. My 30 gallon comes on quite often when I use my drill.
As for the air coming out of the back, do you have more than one place the air is coming out of? Does it only come out when you're drilling or all the time?The outlet on my drill is at the base of the handle. If there is air coming out anywhere else on my drill, I'm not aware of it.
"Pilots: Looking down on people since 1903"
(author unknown)
RV-9, N556RM, O-320, Dual PMags, Catto 3 blade.
FLYING since 2018
Mosquito XEL ready for flight
Old 08-22-2006, 02:33 PM
yes, base of the handle is where I meant. Sounds like it's normal.
Phil
RV9A (SB)
Ottawa, Canada
Old 08-22-2006, 03:26 PM
Paul Thomas Paul Thomas is offline
Mine is the standard one from planetools and I'm surprised at how little air it uses. I believe my compressor is 33 gal, so that does help. I couldn't be happier with that little drill, and I was thinking of leaving it out when I ordered. It would have been a mistake as it makes drilling so much easier and leaves cleaner holes.
