Old 08-07-2013, 03:16 PM
noelf noelf is offline
Default Phase 1 / Phase 2 OP Limits Doc question
I have been flying in Phase 2 for several years now, and keep the required Phase 2 OP Limits document in the aircraft. I also have kept the original Phase 1 document in the aircraft, for no other reason except it is a convenient place to store that document.
I got to thinking the other day that if I were to get "ramp checked", would it be confusing to the FAA folks if I still had the Phase 1 documents in the aircraft along with the Phase 2 documents? The only place that states that my aircraft is in Phase 2 is in the aircraft / airframe logbook, and I don't keep that logbook in the aircraft, therefore I could not prove to the ramp checkers (if required) that the aircraft was operating in Phase 2.
Is this a problem, or am I just over "what if'n" this?
Noel
RV-6A N6NF
tip-up
flying
Old 08-07-2013, 03:21 PM
vic syracuse vic syracuse is offline
Super Moderator
Default Phase I
Don't worry about it. Keep them together. The logbook entry explains which phase you are in. If you ever make any changes such as replacing the prop with the latest wifferdool prop, or something else that could change the FLIGHT characteristics, you will want your phase I limitations as the local FSDO will most likely ask you to make a logbook entry and then adhere to your Phase I limitations.
Vic
Vic Syracuse
Built RV-4, RV-6, 2-RV-10's, RV-7A, RV-8, Prescott Pusher, Kitfox Model II, Kitfox Speedster, Kitfox 7 Super Sport, Just Superstol, DAR, A&P/IA, EAA Tech Counselor/Flight Advisor, CFII-ASMEL/ASES
Kitplanes "Unairworthy" monthly feature
EAA Sport Aviation "Checkpoints" column
EAA Homebuilt Council Chair/member EAA BOD
Author "Pre-Buy Guide for Amateur-Built Aircraft"
www.Baselegaviation.com
Old 08-07-2013, 03:22 PM
Well, who knows what's confusing to the FAA these days.
I have my whole op lim package in the plane, together. But on the first page of the phase one document I wrote, "not applicable, superceded by phase two on (date), my signature and license number".
Old 08-07-2013, 06:02 PM
Gash's Avatar
Gash Gash is offline
I scanned all that stuff into a PDF file and keep it on my iPad (I always fly with the iPad now). I keep the hard copies with my logs in the hangar. I'm like you guys--if the FAA asks for docs, I will just let them see everything.
Karl, Goodyear, Arizona (KGYR) ATP, CFII
RV-14A, Flying
Extra 330LX, Flying
RV-8, Sold
RV-7, Sold
Bearhawk 4-Place, Sold
=VAF= donor 2020
Old 08-07-2013, 06:29 PM
Mel's Avatar
Mel Mel is offline
Please be aware that the Original Airworthiness Certificate and Operating Limitations must be in the aircraft any time it is flying.
RV-6 Flying since 1993 (sold)
<rvmel(at)icloud.com>
Old 08-07-2013, 08:58 PM
Gash's Avatar
Thanks Mel. I have the original airworthiness certificate onboard, however I was not aware that I need the original ops limits...will do that from now on.
RV-14A, Flying
Extra 330LX, Flying
RV-8, Sold
RV-7, Sold
=VAF= donor 2020
Old 08-07-2013, 11:31 PM
RV6_flyer's Avatar
A copy of the OP Lims should be acceptable. When you lose you Op Lims, the Oklahoma City Registry has been known to FAX a copy that is on record so that you can keep flying. I showed the FAA Inspector a photo copy that is printed two sided the last two times that I had a Ramp Check. (Yes I have had two ramp checks in the past 12-months.)
The Airworthiness Certificate (8130-7) MUST be original. IF you laminate it, the FAA Inspector will tell you that you cannot do that as lamination is a modification of the certificate and it must be replaced.
Gary A. Sobek
NC25 RV-6
Flying
3,400+ hours
Where is N157GS
Building RV-8 S/N: 80012
