Old 08-07-2013, 01:13 PM
9GT's Avatar
9GT 9GT is offline
Exclamation HELP ME! I Can't Get My Andair Gas Caps OFF!!
It's been about 4 years since I built my gas tanks. The Andair locking gas caps worked fine then. I greased up the seals, put them on, cleaned up the tops and taped over the caps to keep paint/dust out and left it like that until last month. Last week at the airport, I attempted to open the tank caps to start gassing and calibrating the probes and the key would hardly go in either side. I soaked the key opening and filled the cylinder up with Mouse Milk for several days. That helped some and I can get the key in and wiggle it to bottom out but it won't unlock. I also used WD-40 soaking for 2 days, added heat, poked with a dental pick, blew it out under pressure and still no help. I have already put a bend in one of the keys and don't want to use any more force trying to get the cylinder to turn. The cap will turn a couple degrees then hit the stop. The cylinder will also move a degree or two. My guess is internal corrosion from electrolysis since no contaminants could enter the lock. Any suggestions before I call a locksmith out or destroy the locks??
David C.
Howell, MI
Old 08-07-2013, 01:51 PM
Vern's Avatar
Vern Vern is offline
Default Contact Andair
Contact Andair
Vern Darley
Awarded FAA "The Wright Brothers 'Master Pilot' Award"- for 50 years safe flying
RV-6A N680V / RV-10QB N353RV
Luscombe 8E N2423K 50+years
Hatz Biplane N2423Z soon to be birthed
Falcon RV Squadron Founder
KFFC Hanger D-30
Peachtree City, Ga
770 310-7169
EAA Technical Counselor #5142
EAA Flight Advisor #486336
ATP/CFI/A&P/DAR
Old 08-07-2013, 06:41 PM
pa38112 pa38112 is offline
Fill the key slot with arecroil and then put a vibrator on it to free up the pins. It might take a few minutes. Get the 110 V kind that many drug stores sell.
http://aprs.fi/N153MC
2004 RV6A Flying
2002 RV6A Flying
1978 PA38-112
Old 08-07-2013, 07:22 PM
Bill_H's Avatar
Bill_H Bill_H is offline
I assume you are referring to the buzzing coil used in Model T ignition systems and as a part of the "shower of sparks" aviation ignition systems - also called a trembler coil. But those are DC powered, not 110 VAC. And I don't think they are available at Walgreens!
Or perhaps you mean the electromechanical device used in inverters before the advent of switch-mode power supplies? Again, I don't think you can get them in the Walmart pharmaceutical section!
I don't know why a CD from the British punk band "The Vibrators" would help, and the music section at CVS would not tend to stock an obscure group like that!
Perhaps you mean the sustainer pickup option on some electric guitars, but it would take a specialty music store to obtain one rather than Rite-Aid.
So I am stumped?!! Perhaps someone else can figure this out?
Old 08-07-2013, 07:52 PM
9GT's Avatar
9GT 9GT is offline
I got an email into Andair but no reply as of yet. I got some Kroil penetrating oil at my other hanger up north. I'll bring it home next week and give it a try. Vibrator,,,,,,,hmmmmmmmmm. I thought there might be some kind of magical liquid available I don't know about that would disolve or free up the corrosion.
David C.
Howell, MI
Old 08-07-2013, 07:57 PM
AlphaCharlieBravo AlphaCharlieBravo is offline
coca cola
This is what i used to free pistons from the cylinders in a 1275 motor from my 1964 mini cooper. YMMV Give it a shot.
Arnie Barros
VAF #1401
(N89269) reserved
"Seek to understand before trying to be understood"
Old 08-07-2013, 08:34 PM
DaleB's Avatar
DaleB DaleB is offline
Look near the vibrators at the drug store.
Dale
Omaha, NE
Previous RV-7 project (sold)
Old 08-07-2013, 08:43 PM
Bill_H's Avatar
Chanel #5 might loosen them up. Wouldn't hurt to apologize to them for all that neglect...
Old 08-07-2013, 09:25 PM
9GT's Avatar
9GT 9GT is offline
Oh Boy,,,this thread is drifting to the point of lock down. I goggled the problem and the results are basically an argument of which lubricant to use, dry graphite or liquid. The coke thing might work. I need something liquid that can penetrate and break down the powdery corrosion,,,then I can flush it out and lubricate. From what I found to be a common agreement is that WD-40 will evaporate and leave a varnish like deposit in the pins and springs which is a bad thing. Liquid lubricants also attract dust and the like that can clog things up. Dry lubes like powder graphite are usually over done by the average person and will also cause problems when over done.
David C.
Howell, MI
Old 08-08-2013, 01:50 AM
paul330 paul330 is offline
Somebody in the UK did some tests to find the best freeing agent. It turned out to be a 50/50 mix of acetone and transmission oil. You might try that together with some technical taps with a soft hammer.
Paul
Mercy Air, White River FAWV
RV-10 ZU-IIZ - "Zeus"
Building Bearhawk Bravo - RV-18 not available
2019 Donation Made
