Originally Posted by dspender
... What are the implications of a loose flush rivet that you no longer have access to during the build? What are the repair options?...
The loose rivet will work against the skin/structure and cause fretting. You can sometimes spot a "working" rivet by the perpetual grimey ring around the rivet head.
One loose rivet isn't an immediate downer. But, you'll have to fix it sooner or later. And, the sooner you fix it, the simpler and cheaper the fix is.
If you can't get access to form the shop head, you'll have to use a pop rivet.
--------------Added----------------
Found a link to an interesting article on this:
http://www.mechanicsupport.com/smoking_rivet.html
