08-05-2013, 04:42 PM
AI busted
Out flying yesterday hear this horrendous noise scan gauges and see the AI spinning wildly. It eventually stops all cockeyed. See pic notice left side. Never having problems (800 + hours) I have no idea how much it costs to repair, any ball park ideas? I was also thinking of dumping the vacuum system and replacing with Dynon D6 or Gemini PFD. I am just day/night VFR so do not see the need to get to fancy. I fly a 6. Money is tight. Suggestions , Ideas?
Hopefully I figured out how to add the picture.
Mike Divan
N64GH - RV6,flying
Once an Airman always an Airman (SSgt 78-82)
FREEDOM IS NOT FREE - THANK THE AMERICAN SOLDIER FOR YOURS!
08-05-2013, 04:50 PM
I replaced my electrical AI with a Dynon D10 many years.
Size and weight almost identical, cost vs. AI overhaul very close.
Much more info on the D10.
Never, for one minute, regretted the decision.
RV-6 Flying since 1993 (sold)
<rvmel(at)icloud.com>
08-05-2013, 04:57 PM
Now you've done it
Mike
You are in deep trouble! My AI went out several years ago (in another experimental). I said to myself I should just upgrade rather than spend many hundreds, or maybe a thousand or so dollars on a repair or replacement unit.
I removed the AI, then the next thing I knew, I had the ASI and VSI out of the panel. Then I said, what the heck, I should just pull the whole panel. It cost me many thousands of dollars for a new glass panel. Not to mention the many hours of labor to fabricate and install the new panel....I thought many times during that period, "If only I would have just replaced that AI, I would be flying right now."
edit: I like Mel's idea for a replacement.
08-05-2013, 05:11 PM
fugio ergo sum
One of the most satisfying days in my RV-6 owning life was pulling out the troublesome AI, heading indicator, vacuum pump, vacuum regulator and assorted hoses and slapping in that Dynon D10. Nothing but good about that decision.
Larry Pardue
Carlsbad, NM
RV-6 N441LP Flying
08-05-2013, 06:58 PM
I thought it said AL was busted and I wanted to see what for!
rockwoodrv9a
Williamston MI
O-320 D2A
Awaiting DAR Inspection
08-05-2013, 07:06 PM
Michigan Aviation
(248) 666-3440
Based on field at PTK (Pontiac MI)
Great work, trustworthy and reasonable.
They will give you a quote for repair, overhaul or outright exchange
good luck
James King
RV-7
919
08-05-2013, 08:05 PM
I suppose I should say I am in SoCal.
Mike Divan
N64GH - RV6,flying
08-05-2013, 08:18 PM
Budget
If budget is an issue, you can probably buy a take out for $50.00 to $150.00. It is pot luck on the service life of a used unit, but it would get you back in the air cheap.
Robert Williams
Lee's Summit, MO
RV-8 - Empennage & Wings Done
Working on Fuse
O-360-A1A
1946 Cessna 120
08-05-2013, 08:26 PM
I just had an offer of a use one. Seriously thinking about. Right now budget is an issue. Thanks for the thought. I had not considered that option.
Mike Divan
N64GH - RV6,flying
08-05-2013, 08:44 PM
I thought it said IA Busted!
You could just flag it as in-op and keep flying. I think that's right, yes no?
All my RV has is needle ball and airspeed and vertical speed.
