08-06-2013, 12:08 PM
I might be wrong (I’m not flying yet so this hypothetical), but I’m of the opinion that one NACA scoop is sufficient to provide air to the entire overhead console and it’s potentially how you distribute the air which can drive the one vs two scoop decision. In my case I built a manifold/ducts into my console that delivers air to each of my 4 eyeball vents as I did not want to pressurize the entire console. I also went with only one scoop and no valve/controller. We’ll see how this works in reality.
PP ASEL-IA
RV-10 N728TT - Flying!
WAR EAGLE!
08-06-2013, 12:34 PM
Originally Posted by Auburntsts
I might be wrong (I?m not flying yet so this hypothetical), but I?m of the opinion that one NACA scoop is sufficient to provide air to the entire overhead console and it?s potentially how you distribute the air which can drive the one vs two scoop decision. In my case I built a ?manifold? into my console that delivers air to each of my 4 eyeball vents as I did not want to pressurize the entire console. I also went with only one scoop and no valve/controller. We?ll see how this works in reality.
I like the sound of this. I wonder if anyone else who's flying has done it this way and can give a report.
-Joe Wilbur (N520LW)
Phase II - 11/2017
First flight - 8/2017
RV-10 Build Log
08-06-2013, 03:41 PM
I have been flying since winter, and I can tell you that I am glad I put in 2 NACA inlets. I do not have the controller and just pressurize the OH console. This winter I could feel a slight amount of air leaking around the rocker switches mounted in the OH. Not enough leaks to be an issue. I did use the Steinair eyeballs, which don't let anything pass through when closed. If I did it over, I wou ld not change a thing. IMHO you can never have enough fresh air for passengers!
Bill Peyton
RV-10 - 1125 hrs
N37CP
First Flight Oct 2012
Aviation Partners, LLC
08-06-2013, 09:57 PM
I built ducts into the accuracy console on my last one. No stray airflow. Console is also removable. I made the ducts from cardboard and glass/resin. Molt Taylor style.
Actual repeat offender.
08-07-2013, 08:48 AM
I have 400 hours now with dual NACA vents that pressurize the overhead console. It works very good and you do get some airflow when taxiing. One
NACA will work but 2 is better if you want more airflow especially at lower air speeds in the patterns or taxiing. As for the controller valve I flew for 3 months
without it. I felt it was not needed at the time. Then one day flying in the winter here in Ohio I felt the cabin was quite cold and I noticed the overhead was very cold too touch. After that I installed the controller and now in the winter you can shut the entire overhead off and the cabin is much warmer. Also it is nice to adjust the valve so you can open all the vents wider and get a bigger smoother airflow stream and adjust with the controller.
Also try shutting down the rear vents sometime when someone left them wide open in the rear seat area. With the controller it is very easy. Just my observation after 400 hrs. I would do it the same if building another 10.
FWIW
Geoff
Geoff Combs
RV-10 N829GW 865hrs
1940 Piper J3 Cub
Rans S21
08-07-2013, 09:28 AM
Excellent point. Not enough, by itself, to sway me on the purchase of the controller (of course I reserve the right to reverse myself once I'm flying  ), but it's enough to make me add checking the status of the rear vents to my preflight checklist.
PP ASEL-IA
WAR EAGLE!
08-07-2013, 09:51 AM
Todd not trying to sell you anything or a control valve just trying to give you some good information from someone who has been flying the RV-10 for 400 hrs
and my observations and experiences.
Geoff
Geoff Combs
RV-10 N829GW 865hrs
1940 Piper J3 Cub
Rans S21
08-07-2013, 10:36 AM
Geoff
Oh I know -- you're a good egg and make some really good products and provide outstanding support.  I'm really just pointing out there's more than one solution to the problem. And like I said, I may end up with a controller and 2 scoops before it's all said and done, but I'm going to try a minimalist approach first. If I find it lacking, I can easily add another scoop and/or a controller to my present setup.
PP ASEL-IA
WAR EAGLE!
05-04-2017, 02:54 PM
Just wondering
I might be wrong (I?m not flying yet so this hypothetical), but I?m of the opinion that one NACA scoop is sufficient to provide air to the entire overhead console and it?s potentially how you distribute the air which can drive the one vs two scoop decision. In my case I built a manifold/ducts into my console that delivers air to each of my 4 eyeball vents as I did not want to pressurize the entire console. I also went with only one scoop and no valve/controller. We?ll see how this works in reality.
how this ended up for you, Todd. Did you install one NACA duct or two? Did you get a controller from Geoff? Are you happy with your setup or would you change anything?
Bill Boyd
Hop-Along Aerodrome (12VA)
RV-6A - N30YD - Built '98 / sold '20
RV-10 - N130YD reserved - under construction
donating monthly to the VAF - thanks, Doug
05-04-2017, 03:03 PM
I ended up with just the one NACA scoop and no controller. In flight the one scoop provides plenty of air and the eyeball vents control the flow without problems -- on the ground the flow is pretty anemic but for me it's not a big deal. I'm happy and wouldn't change my setup.
PP ASEL-IA
WAR EAGLE!
| Thread Tools |
Search this Thread |
| Display Modes |
Linear Mode
