Old 08-05-2013, 01:08 AM
Tram Tram is offline
Default How would you prep your interior for a repaint?
Just trying to figure out the best way to do this.
Not sure I want to go stripping all the paint in the interior, as it's in decent shape, just want to change the color. Beige to dark gray.
Anyone have any suggestions about how best to go about prepping for new paint?
Old 08-05-2013, 07:52 AM
6 Gun 6 Gun is offline
Default paint
Wipe down with prepsol to remove oil/wax first then sand and prepsol again then paint.
Bob
Old 08-05-2013, 08:18 AM
Master Designs's Avatar
Master Designs Master Designs is offline
Bob
Great tip for cleaning.
Now, what about if we wanted to remove most, if not all, of the paint and primer that's on the interior before repainting? What's the easiest method and chemical to do so without needing a HAZMAT suit to do it? Not looking to remove the primer under the paint if at all possible, but would like to remove most of the paint as it was hand painted and has some drips...and probably thick in some areas? I have no problem re-primering before paint if need be.
Robert Kramar
Gilbert, Arizona
  • Vans RV-6A
  • Bell 47 D-1 H-13 Sioux Army/Mash Helicopter - Fully Restored and Flying!
  • Vans RV-4 (being upgraded to new panel, firewall, weldments and long gear legs)
Yearly VAF dues paid to date.
Old 08-05-2013, 05:49 PM
Bob
Quick Google search and I can't find anywhere to buy it..
Where can I pick it up?
Is Kleen-Strip "Prep-All" the same stuff?
Old 08-05-2013, 06:12 PM
Greenley's Avatar
Greenley Greenley is offline
I found it here:
http://www.merrittsupply.com/product...-pn-3919s.aspx
Bill Greenley
My RV-10 is now travel, watch out world!!!!!!
Old 08-05-2013, 06:32 PM
rocketbob's Avatar
http://www.superfpaint.com/products/...g-Remover.html
Wicks used to carry gallon sizes, not sure if they still do.
I've used this stuff for a couple of projects, and it works great. Peroxide-based, non-toxic and doesn't stink. You can get it on your hands and it doesn't burn. Good stuff. Spray it on, come back the next morning and big sheets of paint film are laying on the floor.
Bob Japundza CFI A&PIA
N678X F1 Rocket, under const.
N8155F C150 flying
Not a thing I own is stock.
Old 08-05-2013, 06:43 PM
aerhed aerhed is offline
Bob, what kind of paints did it strip? Really?
Actual repeat offender.
Old 08-05-2013, 11:07 PM
Hmmm... That might work for the exterior..
