what size replacement brake lines?
Im confused. Im looking to replace the Van's supplied lines with teflon braided Aeroquip lines (made up in the UK). It seems the most popular replacement lines are size 3 with AN3 fittings, however, all my fittings are AN4. Is it better to use the heavier size 4 line with my AN4 fittings or use adaptors?thxs
David
SB RV 7A IO360 lycoming and Hartzell CS prop
First flight October 2015
