The flange tabs do not conform to the contour of the aft bottom skin. At least not perfectly. Any tips to make this work out any nicer? Do I just rivet away and hope for th best? I don't think I can back-rivet this and a squeezer is out of the question.
__________________ My ATC opinion is NOT an official FAA recognized opinion, so any advice you get from me is ONLY my opinion.
Make little spacers for each rivet where you have space between the flanch and skin. If you don't do that you will see the edges of every flanch through the skin. This technique I can also advice for all the other bulkheads where you see space.
Michael Zimmermann
RV-8 Sold
Happy people don't necessarily have the best of everything,
But they make the best of everything they have.
I reworked/rebent the flanges a bit so the gap is minimzed. I still believe the rivet call out is incorrect depending on how much gap each builder is able to eliminate. It calls for 3.5s but I am thinking at least 4.5s Bucking these rivets will be a bear!
The corners of each tab can be bent inboard allowing the center off tab ,where hole, is to be closer to skin. I recall having to use a little longer rivet also -4 I think.
Bird
Bird
rv8 entire airframe at airport now, painting done, intersection and gear upper and lower fairings done, maybe order engine around first of year or before the next rate increase.
"to fly is a privilege that I am so thankful to God for" http://www.mykitlog.com/tcb328/
This turned out to be a nightmare to rivet for me, I ended up using -4 rivets, they are a lot stronger rivet for that thick bottom sheet. Shhhh don't tell anyone.......
I am currently working on this on my 9. My print calls for 426 3-4 rivets. The skin is .040 thick. I have had good luck with a small rubber grommet over the rivet and between the bucking bar and tab on the bulkhead. It takes quite a bit of pressure on the bucking bar to squish the grommet. I take it out after a few hits, once the rivet starts to expand and hold the tab.
Joe
RV-9A N525XC
Superior IO-320
Dynon HDX
Flying as of 5-4-18
I'm not building yet but why would you not form the flanges as best you can to match the radii of the skin? The upper flanges look like it would take a lot of forming but I think the gap could still be decreased or eliminated. Any problems with this suggestion? Just curious.
