Old 08-01-2013, 04:08 PM
dongor2 dongor2 is offline
Default Tail mounted push bar
My fellow Americans,
I have an RV6 that I need to be able to push and pull around with a pull bar. I would like to know what is available and if the tail wheel spring bar is sturdy enough to move the plane around. My thinking is to design an aluminum clam shell device that clamps around the spring bar that has two "Frankenstien" posts on each side to slide a pull bar over. It would mount just ahead of the two bolts holding the swivel assembly. What do you all think? I have a friend with a CNC machine willing to cut billit for me. Also does W&B come into effect being so far back?
Old 08-01-2013, 04:16 PM
Russ McCutcheon's Avatar
Russ McCutcheon Russ McCutcheon is offline
We just used a longer bolt for the axel and some spacers, this gives ?? or so sticking out each side of the tail fork then we can use a more traditional tow bar, we built ours but I hear there are some out there that work.
Russ McCutcheon
@rv4welder on Facebook
russmccutcheon@gmail.com
We build many of your RV weldments.
Old 08-01-2013, 04:27 PM
flyinga flyinga is offline
I use a 6' nylon strap with a handle (2" PVC about a foot long) on one end and a hook from a motorcycle tiedown on the other end. Just place the hook over the tailwheel spring bar and pull it around backwards.
Jim Averett
RV-8
TS36 - Silver Wings
Fredericksburg, TX
Old 08-01-2013, 06:35 PM
OK thanks guys, so I take it we have enough strength at the spring bar? I have the TW pantalone and it screws to a backing plate so a longer axle bolt may not work in this case. I was also thinking of installing a longer vertical swivel bolt and then bolting on a t-bar reciever just under the nut but above the t plate that has the springs and chain connected to the rudder horn. Yes, no, maybe?
Old 08-07-2013, 02:50 PM
vfrazier's Avatar
vfrazier vfrazier is offline
Check out the simple tow bar construction on this page: tow bar
For a few bucks worth of conduit and a few minutes of welding, you can have a rock solid tow bar that can push or pull the plane using the existing axle bolt and nut.
Vince Frazier
www.f1aircraft.com
F1 Rocket and F4 Raider components
1-888-F1AIRCRAFT (1-888-312-4727)
www.flyboyaccessories.com
RV and Rocket Accessories, Tailwheels, Tools, & More
1-888-8FLYBOY (1-888-835-9269)
F4 Raider - under construction
F1-H Rocket "Crazy Horse" - sold
RV-4 "Chief Pontiac" - sold in 1994, purchased in 2018
