Old 07-29-2013, 09:31 PM
deltamike197 deltamike197 is offline
Default Exhaust pipe vs firewall
Lately I've been having a strange issue with the right side pipe. I have Vetterman straight pipes on an RV-6A with 180 Lycoming FP. When I preflight I notice the top of the pipe is touching up against the bottom skin. Since these pipes have the ball joint forward of the tail pipe I just gently pull it downward to center it in the open space of the bottom cowl and go fly. But when I return the pipe is sitting against the bottom skin again. It obviously has been touching during engine operation because there is a little bit of the skin worn away in the shape of the radius of the pipe. Anyone experience this? How did you fix it? I have flown the airplane for 4 years now but this hadn't happened until recently and nothing has changed so I'm scratching my head. Thanks
Dean
Old 07-29-2013, 10:18 PM
hgerhardt's Avatar
hgerhardt hgerhardt is offline
Yup, my -6 has done it since Day 1. I put a wood dowel inside the 3/8" rubber hose which is the same length as the gap between the steel strut tubes. This works well and in 500+ hours I've only replaced the dowel once. Funny how only the RH side is affected.
Heinrich
Old 07-30-2013, 10:45 PM
Default Exhaust vs firewall
Henrich:
I'm not quite sure I'm following...are you talking about inserting the dowel in the black rubber tube in the exhaust hangar that extends down to the exhaust pipe clamp from the engine sump? And the gap measurement is between which steel strut tubes? Please clarify. Thanks
Dean
----------Original message-----------------------------------
Old 07-31-2013, 06:33 AM
Clint B Clint B is offline
It sounds to me like some oil has worked its way into the smashed tube assembly and needs to be taken apart and cleaned with some solvent. If the tube is lightly scuffed and the hose is clean, the hose will vulcanize to the smashed tube after 1 or 2 heat-cool cycles and stay put. Clint
Old 07-31-2013, 11:23 AM
fixnflyguy fixnflyguy is offline
Default Pipe movement
I have a Vetterman 4 pipe on my -4, and instead of the typical rubber mounts, I fabricated a tube for each side that has Hiem ball ends similar to the flight control hinges.They attach to a flange on the collecter/tip bracket, and another flange attached to the engine case/sump. This way it allows for movement created by vibration and heat/cool, but stays fairly rigid to the engine. Some "factory" aircraft have similar set-ups. It is amazing what happens during start-up/shut-down with "shake" that may be causing yours to move so much. I have about 200 hrs on my set-up, and no cracks, loosnes or airframe contact.
Bill E.
RV-4/N76WE
8A7 / Advance NC
Old 07-31-2013, 11:49 AM
Mike S's Avatar
Mike S Mike S is offline
Senior Curmudgeon
Dean
Is the spinner still lined up with the cowling??
Mike Starkey
VAF 909
Rv-10, N210LM.
Flying as of 12/4/2010
Phase 1 done, 2/4/2011
Old 08-05-2013, 12:30 PM
aguiraf's Avatar
aguiraf aguiraf is offline
I had exactly the same happened on the right exhaust pipe and I would do the similar adjustment by pushing down on the pipe. After a flight the pipe will be right back against the bottom of the fuselage. I fixed this issue by readjusting the steel tubing and rubber hoses provided in the Vetterman exhaust kit. The clamps on the rubber hoses need to be very tigth without damaging them. I have now flown for a couple of hundred hours and have not had to re-adjust.
