Old 07-29-2013, 01:58 PM
ethand ethand is offline
Default Rudder Trailing Edge
I have completed the rudder on my -10 and am happy with the "double flush" rivets and the straightness of the trailing edge.
I am looking for pictures of others trailing edge as my skins do not come together at the trailing edge. I am wondering if I did not put enough bend in them prior to riveting or if this is normal.
Posting before I took pictures but can post some (if I can figure it out) when I get home later.
Anyone have pictures of theirs?
Thanks in advance.
E
Old 07-29-2013, 08:52 PM
tkatc's Avatar
tkatc tkatc is offline
If I recall...I think I could fit a fingernail between the skins on the trailing edge. I filled mine with micro balloons before paint.
Track my RV7A!!
Bought my flying -7A
Building an -8! (Fuse)
Old 07-30-2013, 07:51 AM
YellowJacket RV9 YellowJacket RV9 is offline
My trailing edge is 1-2mm wide, so there is a very small gap between skins. I too will probably fill with something before paint (right now it's mostly filled with pro-seal). If it's straight and consistent width, I say build on!
Chris Johnson
RV-9A - Done(ish) 4/5/16! Flying 4/7/16
Old 07-30-2013, 08:18 AM
rvbuilder2002's Avatar
Thanks in advance.
E
By design, the aft edge of the AEX wedge is slightly aft of the skin trailing edges.
Scott McDaniels
Hubbard, Oregon
