Old 07-28-2013, 04:37 PM
eddieseve eddieseve is offline
Default Weight of P-MAg versus Slick Mag
Hi Guys
Does anyone know the difference in weight between a P-Mag verses a Slick (4300 series) Impulse coupled magneto?
Cheers
Eddie Seve
Sydney Australia
First Flight 16th July 2012
RV-7 Phase 2, 30 Oct 2012
1100 hrs Feb 2020
Old 07-29-2013, 02:00 AM
Andy Hill's Avatar
Andy Hill Andy Hill is offline
A little under 2lbs IIRC?
Andy & Ellie Hill
RV-8 G-HILZ
RV-3B G-HILI very slow build
RV8tors
Old 07-29-2013, 04:55 AM
RV10inOz's Avatar
RV10inOz RV10inOz is offline
What are you up to Eddie?
Enquiring minds want to know
Email is OK to protect the guilty
______________________________
David Brown
DYNON Authorised Dealer and Installer
The two best investments you can make, by any financial test, an EMS and APS!
Old 07-29-2013, 03:12 PM
Thanks for the weight info, much appreciated.
Hi David, I have replaced my right Mag with a P-Mag and it has made an amazing difference to my ability to lean at lower levels, I can do the big mixture pull at 3000ft and all it does now is slow down as I go LOP, no roughness anymore, so far it's made an amazing difference. The feel of the engine is also smoother if that makes sense.
If forgot to weigh the P-Mag and just need to update my weight and balance and POH, although 2lbs on the nose will be insignificant I imagine.
Cheers
Eddie Seve
Sydney Australia
1100 hrs Feb 2020
Old 07-29-2013, 06:31 PM
cjbouldin cjbouldin is offline
I'm considering the same conversion. Is it 2 lbs heavier or lighter?
Chris
RV8/A
5NC5 The Duchy
Old 07-29-2013, 07:16 PM
It's lighter than a normal Mag, just not by a huge amount.
Cheers
Eddie Seve
Sydney Australia
1100 hrs Feb 2020
