Spark plugs
The plugs listed in the parts catalog for that engine are REM40E's. The most current list of approved plugs (Lycoming SI-1042Z) shows the REM37BY, REM38E, and REM40E as approved. However this doesn't really apply as your engine isn't stock. The engine builder should know the correct plug. If I were to recommend a plug for the engine I would use the Tempest UREM38E if the plug leads were 5/8" thread or URHM38E if the leads are 3/4" thread. This assumes that the cylinders are short reach (between 3/8" and 7/16" ish of threads in the plug holes) plug type. Good Luck, Russ
Russell Brown
A&P/IA
"Happiness may never be sensibly pursued as an end in itself, because happiness is the by-product of achievement." -- Northcote Parkinson (paraphrase)
Wasilla, Alaska
