Old 07-24-2013, 01:37 PM
moll780 moll780 is offline
Default static wicks in RV's
Does anyone use static wicks on their RV?
--2008 RV-9A
Austin TX
Old 07-24-2013, 02:21 PM
Mel's Avatar
Mel Mel is offline
When I built my -6 in early '90s, I installed static wicks because of the Loran.
The frequency of GPS negates the need.
RV-6 Flying since 1993 (sold)
<rvmel(at)icloud.com>
Old 07-24-2013, 02:30 PM
Bill.Peyton's Avatar
Bill.Peyton Bill.Peyton is offline
You might want to search the threads for Static Wicks. Here is just one discussion http://www.vansairforce.com/communit...t=static+wicks
Bill Peyton
RV-10 - 1125 hrs
N37CP
First Flight Oct 2012
Aviation Partners, LLC
Old 07-24-2013, 02:32 PM
terrykohler terrykohler is offline
Default Haven't Found a Need for Them
Gil:
I've got around 800 hours on my 9A and have flown through a fair amount of rain and encountered light icing on a few occasions. I have an SL40 for COMM, and haven't experienced any static induced issues. Don't see the need, but someone else may have a different opinion.
Terry, CFI
RV9A N323TP
Old 07-24-2013, 02:33 PM
RV9A Bill RV9A Bill is offline
Default Static wicks
Some years ago Cessna engineers found that static wicks could help keep an electrical storm from blanking out your comm.
Bill
Old 07-24-2013, 03:19 PM
Neal@F14's Avatar
Neal@F14 Neal@F14 is offline
Back when I flew my Cherokee 140 equipped with Apollo FlyBuddy Loran, I noticed that the Loran never would hold a solid lock when flying in precipitation or dusty conditions, but worked just fine in clear dry air. I always wondered if something as slow as a Cherokee would actually benefit from static wicks or not. I guess it probably would've helped, but it's a moot point now
Neal Howard
Airplaneless once again...
Old 07-24-2013, 04:57 PM
I was just wondering... I may pick a couple up at the thrifty booths at oshkosh.
But.. if there is no need then I'd rather put the money into 100LL and save the few oz too.
Originally Posted by terrykohler View Post
Gil:
Terry, CFI
RV9A N323TP
--2008 RV-9A
Austin TX
Old 07-24-2013, 09:42 PM
The real basis of the decision deals with the intended use of your aircraft.
If you intend to fly IMC and therefor need to rely on solid communications not only comm, but ILS/NAV, then you may want to rethink your decision. I had my radios go completely silent while in solid IMC for over 10 minutes. I did not realize it had even happened until I decided to see why the radios had been so silent. It's a good thing I was not on an approach. The wicks were added and it never happened again in the 20 years I owned that plane.
If you intend to only fly VFR, then they are not really necessary. IMHO I would not waste the time or dollars.
If you do add static wicks, you need to also add bonding straps around all the control surfaces to assure good conduction path to the airframe around the hinges and bearings.
Bill Peyton
RV-10 - 1125 hrs
N37CP
