07-22-2013, 02:49 PM
switch current limits
I have convinced myself that a 20 amp switch mean it can withstand 20 amps flow during the on-off cycle. Once contact is made can a 20 amp switch pass through more than 20 amps? What's driving this question is my desire to use a switch, without a relay, to power/de-power my avionics buss. The current is less than 20 amps when turning the switched ON, but once ON the the transponder and VHF radio may occasionally take the load above 20 amps during simultaneous transmissions. Will this be a problem as long as the load is less than 20 amps during the switching cycle?
Thank You
Bob Markert
Littleton, CO KBJC
Reserve Grand Champion Oshkosh 2016
Renegade Opposing Solo pilot and other Dirty Odd Jobs
http://www.rmrairshows.com/
2019 dues paid
07-22-2013, 03:00 PM
Yes, that is going to be a problem. Put in dual switches and split the avionics bus. This might be a good time to make them basically redundant (comm1 on one bus, comm2 on the other, etc) so that if you lose one bus you don't lose all functionality.
07-22-2013, 03:05 PM
Ok so that got me thinking,..... Will a DPST 20 amp switch handle 20 amps per pole (side?) for a total of 40amps? If anyone can point me to basic "switch 101" class I'll gladly do the research
Bob Markert
Littleton, CO KBJC
2019 dues paid
07-22-2013, 03:36 PM
Yes, wire two poles in parallel.
It might not make 40 amps but it will be better than one pole.
Check that the 20 amp rating you are using is a 12 V DC rating.
Gil Alexander
RV-6A N61GX - finally flying
Grumman Tiger N12GA - flying
07-22-2013, 03:42 PM
Just a reminder
I would like to add a reminder also that switches are rated in ac and dc currents, please make sure you buy a switch, for your airplane, that is rated in dc amperes.
The difference is very important. Happy building.
Bird
Bird
rv8 entire airframe at airport now, painting done, intersection and gear upper and lower fairings done, maybe order engine around first of year or before the next rate increase.
"to fly is a privilege that I am so thankful to God for"
http://www.mykitlog.com/tcb328/
07-22-2013, 07:34 PM
Current
Thats a lot of amps for two radios and a transponder what are you using.
Bob
07-22-2013, 07:51 PM
Bob
2 x G3X screens
GMC305 AP controller
Dual ADAHARS
Dual magnetometer's
Dual TCW backup battery
GTN 650
PAR 100EX
GDL 39
GTX 23 ES transponder
proton torpedo generator
i have yet to do the math with a sharp pencil but the GTN Comm and GTX23 in reply mode eats up some amps. there is another thread running right now about an EFIS switch which has me considering moving the screens to the main buss
Bob Markert
Littleton, CO KBJC
2019 dues paid
07-22-2013, 08:38 PM
Originally Posted by bobmarkert
2 x G3X screens
Dual ADAHARS
Dual magnetometer's
GTN 650
PAR 100EX
GDL 39
A VP-X would complement all that awesome equipment very nicely. Use any switch you'd like to turn equipment on/off.
They don't pay me, I'm just a big fan.
Jeff Atkinson
RV-8 #82594 Flying since May 2012
Barrett XP-360, Catto 3-Blade, Dual G3X Touch, GTN-650, VP-X
07-22-2013, 08:52 PM
thanks Jeff,
I thought long and hard about VP-X and decided against it, so that decision is behind me and in my mind irrevociable. I know the cost will be similar for VP-X and traditional CB's. I'm starting to pull wires for a conventianal electrical system.
Bob Markert
Littleton, CO KBJC
2019 dues paid
07-22-2013, 09:02 PM
Personally, I'd put the EFIS/EMS/ADAHARS/etc on an "instruments" breaker and switch circuit that is separate from the radios/xponder breaker and switch. Having it all on one single "avionics" switched circuit is putting a lot of eggs into one basket. Just my personal opinion anyway.
Neal Howard
Airplaneless once again...
