Holes for conduit
Consider not making the holes. I routed the conduit through the lightening holes. I made a small bracket, sort of look like an "L" with a little hook at the end, about 1/4" in width, about 1" in height. I riveted the "L" to the rib with the bottom just at the edge of the hole. I zip tied the tube to the "L" and put a dab of blue RTV to stabilize the installation at each rib. Works great, just position the zip tie end to where it will not cut you. Regards, John.
John Clark
Moundridge, KS
RV-9A 90512 N6699 Sold
RV-12 120323 N6699Z 410 hours
dues paid 2018
