Old 07-19-2013, 07:44 PM
alpinelakespilot2000 alpinelakespilot2000 is offline
Default % power, prop pitch, rpm and temps relationship
Hypothetical question regarding fixed pitch props:
Assuming two identical engines are both producing 75% power but one has an underpitched prop and the other has an overpitched prop, would engine temperatures (CHTs primarily) be the same on both engines? Stated differently, suppose it it takes 2700 rpm for one engine to produce 75% power but only 2500 rpm for another engine to produce 75% power (because of differences in prop pitch), assuming all else equal, would you expect the higher rpm engine to generate higher CHTs due to faster moving parts or should temps be the same on both engines since both are producing the same power?
Thanks.
Steve M.
Ellensburg WA
RV-9 Flying, 0-320, Catto
Donation reminder: Jan. 2021
Old 07-20-2013, 12:39 AM
skylor's Avatar
skylor skylor is offline
Thanks.
I would expect the lower RPM engine to produce higher cylinder head temperatures than the same engine producing the same power at a higher RPM. The reason being is that the slower turning engine will have a smaller theta PP (crank rotation angle when peak cylinder pressure occures) and a higher maximum cylinder pressure. However, the slower turning engine will be more efficient due to less pumping losses (from higher manifold pressure/more throttle).
Skylor
Last edited by skylor : 07-20-2013 at 04:06 PM. Reason: Corrected mistake re: leaner mixture.
Old 07-20-2013, 12:53 AM
RV10inOz's Avatar
RV10inOz RV10inOz is offline
I would expect the lower RPM engine to produce higher cylinder head temperatures than the same engine producing the same power at a higher RPM. The reason being is that the slower turning engine will have a smaller theta PP (crank rotation angle when peak cylinder pressure occures) and a higher maximum cylinder pressure. However, the slower turning engine will be more efficient due to less pumping losses (from higher manifold pressure/more throttle) or leaner mixture.
The first part in bold is 100%, well done.
______________________________
David Brown
DYNON Authorised Dealer and Installer
The two best investments you can make, by any financial test, an EMS and APS!
Old 07-20-2013, 04:10 PM
skylor's Avatar
Default Correction
And I corrected the mistake in my post by removing the last 3 words...
