Old 07-19-2013, 10:28 AM
Bavafa Bavafa is offline
Default Lower oil pressure with camguard
I was wondering if any one has experienced a lower oil pressure when adding camguard additive? I did an oil change and have added camguard, about 9oz in 7Q oil and my oil pressure was at the lowest that I have ever seen in my engine. It has been always stayed between 78-85 PSI depending on temp, but the other day by the end of a 30 minute flight it was at 56 psi with the oil temp in its normal range of 181F
Mehrdad
N825SM RV7A - IO360M1B - SOLD
N825MS RV14A - IO390 - Flying
Dues paid
Old 07-19-2013, 11:10 AM
Neal@F14's Avatar
Neal@F14 Neal@F14 is offline
I've not noticed any significant change in my oil pressure with CamGuard added to the oil. I'm running Phillips 20W50 multi-weight oil and put in about 3/4 of the 1 pint bottle to 7 quarts oil. On my long trip to Idaho last month, there were periods of long climbs at slower airspeeds where my oil temps hit 200 and oil pressure stayed right around 80 psi.
Neal Howard
Airplaneless once again...
Old 07-19-2013, 11:41 AM
LifeofReiley's Avatar
LifeofReiley LifeofReiley is offline
I use 8 OZ of Camguard to 7 Qts Aeroshell W100 Plus, no change in oil pressure or engine temp noted in 300 hrs.
Reiley
Retired N622DR - Serial #V7A1467
VAF# 671
Repeat Offender / Race 007
Friend of the RV-1
Old 07-19-2013, 11:42 AM
Mike S's Avatar
Mike S Mike S is online now
Senior Curmudgeon
Did not notice any change.
Mike Starkey
VAF 909
Rv-10, N210LM.
Flying as of 12/4/2010
Phase 1 done, 2/4/2011
Old 07-19-2013, 11:52 AM
What rpm was the engine running with 56 psi? As low as 25 psi is "in the green" at idle rpm.
Another datapoint for you - I've used Camguard for 2-3 years (wow, did you see what spell correct did before I changed it?) and have never noticed a reduction in oil pressure.
Kyle Boatright
Marietta, GA
2001 RV-6 N46KB
2019(?) RV-10
Old 07-19-2013, 02:45 PM
Thanks folks for sharing your experince, it seems it was a mistake on my part that I looked at my oil pressure at very low RPM (800+) . I went for a short flight again today and all is normal.
Mehrdad
Dues paid
Old 07-19-2013, 03:33 PM
Good News... Camguard is Good Stuff!
Reiley
VAF# 671
Friend of the RV-1
Old 07-20-2013, 08:13 AM
jlk jlk is offline
Camguard and Aeroshell W100 Plus. I think that is redundant. Maybe I am wrong, but the Plus has almost the same stuff as the Camguard in it. I have been using Aeroshell W100 and adding Camguard at the oil change and then use Aeroshell W100 Plus when adding oil between changes in my Columbia 400.
Jordan Kaplan
RV-7A
Just starting the journey
QB Fuse and Wings in the shop
Old 07-21-2013, 07:02 AM
BillL BillL is offline
Lycoming seems to agree. I just watched (last night) the DVD that came with my new engine and they say this exactly, "Plus" does not need Camguard. Has this changed?
Bill
RV-7
Lord Kelvin:
Old 08-06-2013, 08:19 PM
n761tj n761tj is offline
The Aeroshell Plus has 0.9% Butylated/isopropylated triphenylphosphate anti-wear, 0.05% rust inhibitor and 0.5% copper corrosion inhibitor.
Camguard is 100% active and when used at 5% provides vastly improved performance over the Plus. It provides 25 times the rust inhibitor, much better anti-wear performance, true anti-scuff (does not need activation), deposit control (the only aircraft oil product that offers this) and seal conditioning (the Aeroshell anti-scuff attacks seals but Camguard protects them). Here is a 24 hour test conducted on a new push-rod tube seal after heating the Aeroshell Plus (or 15W-50) with a little water and a piece of copper. http://aslcamguard.com/aircraft/test...-conditioning/
There are no chemical similarities between Camguard and the $0.15 worth of additives found in a quart of Aeroshell Plus.
Ed
