07-17-2013, 08:56 PM
Help me find the Oil Pressure fitting
I'm gearing up to hang this beast and looking to find the port for the oil pressure restrictor fitting. Please Help
Overall picture of Engine:
Here there are two ports with allen plugs adjacent to the upper right engine mount. They appear to serve the same purpose? Should i use one of these (left or Right)?
Here is a larger fitting with an allen plug in front of what I believe is the prop governor adapter, what's this one for?
Derek Hoeschen
EAA Tech Counselor
RV-9A #92103 - N803DK
G3X, Superior XO-320, Dual Pmags, Catto 3B
www.mykitlog.com/dbro172/
1974 Bellanca Super Viking - N16AW - Flying
RV-8 #83565 - N184DK - building
1968 Mooney M20C - N6801N - Sold
1956 C-182 - N744W - Sold
07-17-2013, 09:01 PM
There are 2 plugs just above the right mag - either will work.
RV-12 Build Helper
RV-7A...Sold #70374
The RV-8...Sold #83261
07-17-2013, 09:27 PM
Plug
The plug on the side is difficult to access after the engine is mounted, it is very close to the mount ring tube. The aft facing plug is much more accessable. Most older engines have only the side plug.
07-17-2013, 10:08 PM
Senior Curmudgeon
You do know about using a restrictor fitting there don't you??
Mike Starkey
VAF 909
Rv-10, N210LM.
Flying as of 12/4/2010
Phase 1 done, 2/4/2011
07-17-2013, 10:21 PM
Yes Sir, the restrictor fitting and instructions came with the firewall forward kit from Vans. Thanks for checking, im at that stage where things are becoming real new, real fast
Derek Hoeschen
EAA Tech Counselor
07-17-2013, 10:22 PM
Senior Curmudgeon
Good deal, carry on
Mike Starkey
VAF 909
Rv-10, N210LM.
07-18-2013, 05:26 AM
The lower, large diameter plug is an oil return to the sump.
Dan Horton
RV-8 SS
Barrett IO-390
07-19-2013, 08:46 AM
I purchased my RV already built. I haven't the technical skills to change the batteries in my flashlight. Still, I enjoy reading these post where you guys help each other. Why???
Evan Tullos
Purchased & Flying RV-9A
Brandon, MS
N159RV
(601) 826-6587
07-19-2013, 09:13 AM
Senior Curmudgeon
Probably testosterone driven
Mike Starkey
VAF 909
Rv-10, N210LM.
07-19-2013, 09:15 AM
Senior Curmudgeon
Which Photo??
In the top photo it appears to be the oil screen ----- large flange and safety wire.
Mike Starkey
VAF 909
Rv-10, N210LM.
