I believe Dan coined the phrase, "Suicide Mode", referring to countersinking using the long deburring shaft in your drill, with the appropriate countersink attached at the end. The "suicide" refers to the fact that you have no countersink stop cage, and it can get away from you - chewing through more than you wanted
I actually prefer it in places, but be warned - practice on some like material before you go that route (ask me how I know). The idea is that you can get the countersink into some pretty tight places, like the area of the angle of the aileron bracket. Check your depth using some pre-dimpled scrap of the same thickness.
