Old 07-17-2013, 01:21 PM
CharlieWaffles's Avatar
CharlieWaffles CharlieWaffles is offline
Default Getting Baffle Fabric to Seal
I have noticed that some of my baffle fabric isn't sitting as flush against the upper cowl as I would like. I can see some "puckering" or "waves" along the back side where it should be flush with the cowl interior. What is the best way to encourage this to sit flush? A small cut V channel in the pucker?
CharlieWaffles - But you can call me "Mark"
RV-10
N928MT
Flying - AKA Still Tinkering
Build Project Site
Old 07-17-2013, 01:25 PM
Brantel's Avatar
Brantel Brantel is offline
I found that too wide a strip is a problem. Have to sneak up on the best width. Don't go too far or it will flip back...
Brantel (Brian Chesteen),
RV-7/TU, #72823, N159SB
Track N159SB (KK4LIF)
Old 07-17-2013, 01:26 PM
So cut the baffle back to a shorter height?
RV-10
N928MT
Build Project Site
Old 07-17-2013, 01:38 PM
Brantel's Avatar
Thats what I did, not saying that will fix yours but it worked for me.
A few short slits in the pucker places should not hurt either as long as the uncut part still contacts the cowl.
Pretty soon you will see marks on the cowl and the rubber and will be able to tell where your leaks are. It happens pretty fast.
Baffle sealing is more art than an exact science. It takes trial and error.
Old 07-17-2013, 01:41 PM
Mike S's Avatar
Mike S Mike S is offline
Senior Curmudgeon
I ended up changing the fabric reinforced stuff for the orange silicone material.
Mike Starkey
VAF 909
Rv-10, N210LM.
Flying as of 12/4/2010
Phase 1 done, 2/4/2011
Old 07-17-2013, 02:04 PM
alpinelakespilot2000 alpinelakespilot2000 is offline
Remove the couple outboard rivets, pull fabric down lower and re-rivet. This should have the desired effect. Did for me.
Steve M.
Ellensburg WA
RV-9 Flying, 0-320, Catto
Donation reminder: Jan. 2021
Old 07-17-2013, 05:26 PM
Any good rule of thumb on how much fabric should be in contact with the cowl itself? I'm wondering if my fabric is indeed too tall and is bending over too much.
RV-10
N928MT
Build Project Site
Old 07-17-2013, 06:07 PM
aerhed aerhed is offline
Just cut one slit from the point of the pucker out. That'll make that pucker lay down. Later after it imprints, you can reevaluate.
Actual repeat offender.
Old 07-17-2013, 10:22 PM
jchang10 jchang10 is offline
Looks very familiar. I had the same issue in the same corner. In my case, it never ended up laying flush.
I would do as airplaneslakes says. Rerevit with fabric pulled down to contour better with the upper cowling shape. You should end up with puckers or folders in between the rivets which can easily be sealed with a bit of RTV.
#40533 RV-10 Builder and CFI
1/2006 Started build
10/19/2011 First flight
