w/a Donation
VAF on Twitter:
@VansAirForceNet
Old 07-16-2013, 07:53 PM
Bill_H's Avatar
Bill_H Bill_H is offline
Default An Arch Metal (Quonset) Hangar with Unusual Doors
I had enough level land to put in a small 1260 foot strip for My RV12. So I also built a hangar and the doors are kind of unusual. Here are the details.
I built a metal arch building. NEVER AGAIN!!! The materials cost is cheap but there is a lot of labor. And after built, you have a LOT of limitations. I included 3 skylights, a really good thing. Lets in lots of light.
Don't believe what the manual says about using a scaffold and ropes to raise each arch! You will need a boom truck for a building of any size. This is a 40x40 foot building, 20 arches.
Me plus 4 other people and the boom truck, about 4 days of raising the building what with delays. LOTS OF BOLTS! You loosely assemble the arches on the ground, raise, bolt together, then tighten. You will have previously poured footers and bolted the attachment base to those.
I bought a building with the arches and one end wall. The other wall is for the custom hangar doors and I designed and built it from scratch. Here are the limitations:
1. Not spend a whole lot. You notice the hangar floor is gravel, not a slab.
2. I wanted a 10 foot height door (in the middle) and MAXIMUM POSSIBLE opening width. To get the plane in and out plus a small tractor if possible without moving things around. So if you do a fully rectangular door, you lose opening width because the top of the door hits the arch. If you have a vertical bifold door, it is even worse because when raised, the two panels take up height, meaning you need to raise the whole thing, then the door gets narrower.
3. Accordian-style doors that open to the side don't take up a lot of width when open, but have to have a rectangular opening which wastes opening width.
4. Imagine a conventional garage door "on its side" that opens horizontally rather than vertically. The problem with that is you have to build some interior walls and somehow support the track. That also reduces opening width.
5. Then there are the side-opening sliding doors that rely on a separate frame built in front of the building. More steel, footers, supports, etc, not cheap.
6. The arch building makers say that the arches themselves are NOT to support other structures.
I came up with the following. It is inspired but modified by the hangar doors of a friend that is building a Zenith high-wing. It maximizes both door height and width and is easy and fast to operate.
A. The key is the two "bent" metal support posts at the edge of the door opening. These are made of 4x4 square metal tubing and all the welding was done by a talented local guy. These are base-bolted to the footer. At the top of each post is a flat plate.
B. The two posts hold up the top wall. The bottom of that wall is a sandwich beam made of treated 2/4 and 3/4 OSB. That beam was made with construction adhesive, nails, and staggered joints. It supports a conventional 2x4 stud hall that sits on top of the beam. Several half-inch bolts go vertically THROUGH the beam and into the baseplate of the stud wall. OSB was used to skin the outside of the stud wall and the bottom 2 feet of the inside. After that wall was erected and the temporary supports under the beams removed, it did not sag even a quarter inch! (WHEW!)
C. The top of the stud wall is anchored to the first arch with 2x4 sections and longer bolts replacing some of the existing ones where the arch sections are joined. This is for wind load but there is not a lot of wind from the East which is how the hangar faces. Filler wall sections to the side and vinyl siding finished it up.
D. Now the doors. There are 4 sections. They open OUT as shown, riding on inflatable wheels and motorcycle shocks (sourced from Ebay.) The two inboard wheels swivel, the outboard do not. You can open one or both inboard sections and then one or both full doors. They are covered in lightweight, translucent, flexible plastic sheets. These can also be obtained in clear. They let in a lot of light. Note the "door-in-a-door on the right that helps maximize opening width.
E. When closed, each door section has a spring-holder at the top and a bent rod at the bottom that goes into a hole in the concrete. Very secure. The bane of doors like this is WIND. So if you open each inboard door, there is a 3/4 ID metal pipe driven into the ground at a fully open position for the bent rod to be inserted into. There are two more for the different rod positions when both panels are open. My friend has just two big door panels (not 4) and they are problematic in a light wind. These smaller panels are easier to handle.
F. Rolls of thin rubber mats from Home Depot are cheap. Cut into about 9 inch strips, they make for a closing gasket on the bottom. Some foam rubber garage door seal is applied at the bottom of the arched upper wall. The seal is very good - trying to keep wasps and critters out. I will be adding lights to the front and back walls pointing down at an angle.
If I had to do it over again I would build a conventional square steel building. I think the overall cost would be about the same - maybe slightly more - but the flexibility of the interior is MUCH better than the arch "Quonset" style.
Bill H. RV-12 "Sweetie" N412BR Flying 1 year!
Old 07-16-2013, 09:42 PM
That's an impressive bit of work.
Good job!
Dave
Old 07-17-2013, 02:17 PM
LarryT LarryT is offline
Default Clark County WA 60mph wind load
When I submitted my plans to the Clark County WA building department, I was informed that the building would have to meet a 60 mph wind load requirement with the doors open!
When I suggested that I wouldn't be going flying if the wind was blowing 60 mph, it fell on deaf ears.
The structural PE calculations cost $1000 in 1992. Even though earthquake requirements had just gone up for our area, the PE's calculations, not surprisingly noted that "wind load governs." the cost of the hangar increased by over 33% because of the changes
There are two re-bars encircling the perimeter foundation, the columns bolt to "j--Hooks" that catch that rebar. 48 cubic yards of concrete was used in the floor and foundation of this 2000 square foot hangar.
For those of you that live near W52, in the event of a natural disaster, my hangar will be the last building standing in Clark County. You are welcome to bring a sleeping bag and roll it out in my hangar :-)
When I retire, I hope I can move some place where there is more common sense.
Larry Tompkins
544WB -6A
W52 Battle Ground, WA
Old 07-17-2013, 03:03 PM
DennisRhodes DennisRhodes is offline
Default Arch Hanger
We have a similar hanger and you are correct about the construction. DIFFICULT without a lift and about four people! The march winds blew down a couple of our arches during construction but salvaged out OK. We have a poured floor in a 60 X 80 but never have closed in the ends. The biggest complaint is that all the dirt and trash does blow thru. Nice looking door design and finish for what normally is a difficult product to modify. No worry about snow loads in Georgia!
DRRhodes
2023 VAF Supporter
RV9 N908DR
Old 07-19-2013, 03:37 PM
vfrazier's Avatar
vfrazier vfrazier is offline
Just so this will be easy to find for others, here is another hangar door system that is unusual. They worked very well, were very sturdy, and reasonably priced to boot.
hangar doors
The key to these doors are the curved tracks that allow the doors to slide around the corner and go into the hangar. This means you can't put stuff on the side walls, but it wasn't a problem.
The end doors simply hinge in and are parallel to the side wall when open. This saves the cost of an expensive man door. Worked great.
Although these doors weathered many very severe storms, an F2 tornado made a direct hit on this hangar 2 years ago and knocked it and many other buildings to the ground. (Ugh.) The only thing salvageable were the doors. They are tough. They are all being reused!
Vince Frazier
www.f1aircraft.com
F1 Rocket and F4 Raider components
1-888-F1AIRCRAFT (1-888-312-4727)
www.flyboyaccessories.com
https://www.cleavelandtool.com/
RV and Rocket Tools, Accessories, Tailwheels, & More
1-888-8FLYBOY (1-888-835-9269)
F4 Raider - under construction
F1-H Rocket "Crazy Horse" - sold
RV-4 "Chief Pontiac" - sold in 1994, purchased in 2018
Old 07-21-2013, 01:34 AM
osxuser's Avatar
osxuser osxuser is offline
We have those roll around the corner doors at my current hangar. After 30ish years, they are garbage. Hangars don't stay straight, so the doors meet tons of resistance going around the corners.... It sucks.
RV4 wing in Jig @ KPOC
RV7 emp built
Old 07-21-2013, 08:54 PM
aarvig's Avatar
aarvig aarvig is offline
It may have been a lot of work...but you did a fabulous job. Looks awesome. By the way the plane looks great too.
Aaron Arvig
RV-9A
Empennage Done
Wings-In Progress
N568AK Reserved
SOLD?but I'll be back
Old 07-24-2013, 09:27 AM
vfrazier's Avatar
Steve,
It must be the difference in construction techniques or materials. Ours worked perfectly for 15 years until the tornado removed the building! The tornado also destroyed many other nearby buildings, so it wasn't the doors fault.
We were all very pleased with them. For those on a tight budget, they are a valid option, if built properly. Sorry to hear that you weren't happy with yours.
Vince Frazier
www.f1aircraft.com
