Closed Thread
  #81
Old 08-17-2013, 11:53 AM
MCA's Avatar
MCA MCA is offline
Default Update Aug 17
We've been making progress on the design, although we haven't finalized the feature set. With all the great suggestions it appears the best strategy isn't to put everything in one box, but have several products in the product line that address different needs.
Right now we've been working on the schematic with the intent of building a prototype board to perform lab testing on the robustness of the system itself as well as insuring the circuit protection and features work as planned. Here is Josh working on the PCB layout:
So once we go through the review process and order the PCBs we'll have a few proto boards to begin lab testing with.
Based on your feedback, we've also been looking at a way to simulate a standard shunt so that you can connect your EFIS ammeter gauge inputs directly to the PPS. This would mean NO stand-alone shunts on the firewall at all. Very clean and simple!
Marc Ausman
RV-7 980 hours, IO-390, VP-X (sold)
RV-8 (flying a friend's)
Thinking about low and slow backcountry build.
VAF Advertiser - Aircraft Wiring Guide
Book to help with experimental aircraft wiring.
  #82
Old 08-20-2013, 02:01 PM
MCA's Avatar
MCA MCA is offline
Default Starter Interlock
We received feedback in this thread and other threads that builders would like some sort of security feature on the starter circuit.
Below are two ideas - what do you think? Any preference?
A small keypad and status light (2 pictures)
A keyfob - press the button and the starter is enabled. We can also include a status light for the instrument panel.
Marc Ausman
  #83
Old 08-20-2013, 02:49 PM
NovaBandit's Avatar
NovaBandit NovaBandit is offline
Personally, I had something more like a car door keypad in mind:
Much more compact on a crowded panel.
Ed Kranz
RV-10 N829EC - Flying
First Flight: 8/29/15
KSGS - Fleming Field, South Saint Paul, Minnesota
YouTube.com/GoodPlaneLiving
-- Build Timelapse and Travel Videos . . GoodPlaneLiving.com -- Build and Travel Blog
  #84
Old 08-20-2013, 03:32 PM
southtarnation's Avatar
southtarnation southtarnation is offline
I like the fob! When I had metioned earlier in this thread about a proximity fob I had reconsidered because althogh it would be secure (not start) while Im away if I happen to be nearby an an unsupervised kid or numbskull gets in it would be "hot". Your solution takes care of that while still be remote operated and keyless with no code to remember. Id be happy with either but the door lock style pictured above looks beeter with the backlighting than the pad you have. Great work!
Jesse
'89 RV-4, N2626C - purchased flying
Converted to Fastback - Sliding Canopy - Tall Gear
Dynon Skyview w/ acc. & VP-x Sport
Catto 3-Blade (gen. 1)
Based: KPGD
  #85
Old 08-20-2013, 03:46 PM
Sig600 Sig600 is offline
Is this something the current vp-x could implement? Only problem with the key fob is what if you lose it on XC? Or the battery dies, or you take it swimming, etc?
Next?, TBD
IAR-823, SOLD
RV-8, SOLD
RV-7, SOLD
  #86
Old 08-20-2013, 03:51 PM
RV7Guy's Avatar
RV7Guy RV7Guy is offline
Default Security??
Is this really an issue? I see a solution to problem that doesn't really exist. I think if had RV's being stolen on a regular basis, we'd know about it, then I'd be concerned.
How many have some sort of security device now?
I rather see a focus on an Aux power lead or some of the other suggestions here.
Darwin N. Barrie
Chandler AZ
www.JDair.com
RV-7 N717EE-Flying (Sold)
RV-7 N717AZ Flying, in paint
EMS Bell 407,
Eurocopter 350 A-Star Driver
  #87
I'd prefer an old-fashioned key. When I'm on a trip, I often put a key on a loop of string around my neck, and it's secure swimming, jogging, etc. Easy to hide a spare, very reliable, waterproof and easy to check that's it's around my neck.
With a bit of luck maybe - just maybe - we can get a key that matches the Newton locking gas caps and even include a canopy lock set.
If so, then one key will do the airplane.
Dave
  #88
Old 08-20-2013, 04:19 PM
rjtjrt rjtjrt is offline
Key fobs in the car context have a habit of failing (ie breaking), and it is a bit irritating to be absolutely stranded.
This seems to me to be adding complexity to solve a non existent problem. The equivalent of in the medical field, "the worried well" patient.
So I think such a security feature should definitely be optional, as for me it would severely make me shie away from your product if it is a single point of failure ( not safety related, but stranded unless hand prop the aircraft).
John
  #89
Old 08-20-2013, 04:22 PM
MCA's Avatar
MCA MCA is offline
To clarify, this is envisioned as a separate product that can optionally be used with the VP-X, the primary power system, or old-fashion wiring.
Marc Ausman
  #90
Old 08-20-2013, 04:43 PM
Marc
Thanks. Much relief.
In that case, I would suggest a mechanical key is more reliable, smaller to carry, but I guess more wiring to panel required.
John
Closed Thread
