Originally Posted by sf3543
The Dynon pitot tube has provision for the AOA idicator. One tube is for Pitot and one is for AOA. I just capped off the AOA tube and all works well. One side note, the tubing is smaller than the 1/4" aluminum tubing supplied for the pitot line, by VAN's, so you will need a -3 to -4 reducer and the appropriate flared fittings to make it work. If you use the Dynon/SafeAir installation package, everything should work out fine.
sf3543 is right about the reason for two tubes. I used flexible tubing with barb fittings on my installation and it worked well. On my new heated pitot installation, I am converting to all aluminum tubing.
By the way, my Dynon unheated pitot tube has been spoken for.
Steve
N174AS
RV7, 230hrs
