Old 07-13-2013, 12:08 AM
jchang10 jchang10 is offline
Default Exhaust gasket leak?
I just noticed this on a couple of cylinders. It is a bit of grey or white discoloration around the exhaust port. It looks like the exhaust must be leaking in this area? 270 hours on engine. nuts are torqued to at least 100 in-lbs.
Any recommendations? Should i just replace the gaskets? With or without sealant? Or just torque the nuts down more?
I am pretty sure this gasket was installed dry without any sealant or RTV.
Thanks for the input!
Jae
#40533 RV-10 Builder and CFI
1/2006 Started build
10/19/2011 First flight
Old 07-13-2013, 06:39 AM
Walt's Avatar
Walt Walt is offline
Doesn't look like a leak to me, torque the nuts to 160 -180 in/lbs and keep an eye on them (not sure where you got 100 from but that is not correct.
Walt Aronow, DFW, TX (52F)
EXP Aircraft Services LLC
Old 07-13-2013, 09:47 AM
turbo's Avatar
turbo turbo is offline
looks like new. is the hose clamp for the egt? nice pic!
TURBO YES =VAF= Payed Jan2019
Ed D'Arcy
addicted pickle ball player
Old 07-13-2013, 12:36 PM
EGT hose clamp appears to be hung up on something? It should be snug on the exhaust pipe, all the way around.
Old 07-13-2013, 01:30 PM
ok, thanks. I'll snug it up more, clean and watch it. I will probably go ahead and pull it all off and replace the gaskets eventually.
oh that is just the tail of the hose clamp which is just hanging loose.
i just got a chance to review the vetterman instructions, and they clearly say tighten to 140-180 inlbs and to check the torque periodically. i will have to add this to my condition inspection checklist, which i don't think is on there now. it does seem to me that the nuts have loosened up since it was first installed.
thanks again!
Jae
Old 07-13-2013, 02:50 PM
Rick_A's Avatar
Rick_A Rick_A is offline
Originally Posted by jchang10 View Post
i just got a chance to review the vetterman instructions, and they clearly say tighten to 140-180 inlbs and to check the torque periodically thanks again!
Jae
The original instructions I received from Vetterman specified 140 in lb. I mentioned this to Walt one day (since I'm lucky enough to have my plane in his hanger) and even showed him the Vetterman instructions. Walt called Vetterman and bottom line is that some of Vetterman's printed instructions incorrectly specified 140 in lbs.
I ran with 140 in lbs for about 3 years (checking torque every 50 hrs) with no problems. After Walt talked to Larry, I bumped the torque up to 180 in lb.
Rick Aronow,
A&P
Flying 7A Slider;
RV-12 SOLD
Highland Village,TX
