Old 07-12-2013, 05:09 PM
Dbro172's Avatar
Dbro172 Dbro172 is offline
Default New XP 320! - Prop Governor on Fixed Pitch?
Just received my new Superior XP 0-320 One thing that confuses me is that I had the engine built for fixed pitch however it has a prop governor installed and an oil line from the front of the case to the prop governor (or maybe its an adapter). There is an entry in the Logbook stating the governor and oil line must be left in tact. Seems Odd.
Why?
Brown line at bottom
Derek Hoeschen
EAA Tech Counselor
RV-9A #92103 - N803DK
G3X, Superior XO-320, Dual Pmags, Catto 3B
www.mykitlog.com/dbro172/
1974 Bellanca Super Viking - N16AW - Flying
RV-8 #83565 - N184DK - building
1968 Mooney M20C - N6801N - Sold
1956 C-182 - N744W - Sold
Old 07-13-2013, 07:12 AM
mahlon_r mahlon_r is offline
The oil pressure the builds up in the hollow of the nose bore of the crankshaft is being vented back through the hose and adapter. Without venting that pressure you will blow the front plug out of the shaft and have a big oil leak. If you wanted to remove the hose and drive adapter to save weight then you could remove the front plug in the shaft and pierce the rear one to provide a vent for the oil pressure and then install anew front plug. Of course if you ever wanted to go constant speed, you would then have to replace the rear plug with a non pierced one.
"The opinions and information provided in this and all of my posts are hopefully helpful to you. Please use the information provided responsibly and at your own risk."
Old 07-13-2013, 08:30 AM
Dbro172's Avatar
Default Thanks,
Is it very common to do it this way? I guess I figured they would have just plugged and pierced. I guess this would make for a pretty simple swap to constant speed.
Derek Hoeschen
EAA Tech Counselor
