Old 07-12-2013, 04:42 AM
bobmarkert's Avatar
bobmarkert bobmarkert is offline
Default Need 426 5-X Soft Rivit
I need a few AN 426-5x SOFT rivets
I always cringed when I read about builders making extra holes while dimpling. Yep........ now I can say been there-done that. The good news it intersected the intended original hole. My fix was to drill the hole to include both holes and use a #8 screw dimple die. An AN 426 5 rivet fits perfectly and it looks good (OK???). I doubt it will be discovered except by the most fastidious of builders.
I do not want to try to set a regular 426-5 because it is on a curved surface (Flap) and I am concerned I could distort the skin while setting such a large rivet. Does anyone have any AN 426-5 SOFT rivets (any length ok, I'll cut it)? I really don't want to buy the quantity required by the supply houses to get just a few. Hopefully I'll never need them again.
any help appreciated.
Bob Markert
9670 W. Gould Ave
Littleton, CO 80123
Bob Markert
Littleton, CO KBJC
Reserve Grand Champion Oshkosh 2016
Renegade Opposing Solo pilot and other Dirty Odd Jobs
http://www.rmrairshows.com/
2019 dues paid
Old 07-12-2013, 07:22 AM
DaAV8R DaAV8R is offline
Default Soft Rivets
I have some soft 470's but not any 426's. I would check with B & B Aircraft in Gardner, KS. They have a pretty good assortment of odd stuff and they might be able to fix you up.
Robert Williams
Lee's Summit, MO
RV-8 - Empennage & Wings Done
Working on Fuse
O-360-A1A
1946 Cessna 120
Old 07-12-2013, 05:44 PM
rwarre rwarre is offline
Default Maybe
I remember buying some soft rivets in the final stages of my build but can't remember what I did with them. I'll be able to check tomorrow and let you know.
Old 07-12-2013, 09:47 PM
aviationone's Avatar
aviationone aviationone is offline
I have the following AD Rivits but no A Rivits. If you want to try some ADs let me know and I would be happy to mail you out some.
The 1097s may work for you with the smaller head.
1097 AD 5-X
1097 AD 6-X
426 AD 5-X
Tom Powers
RV8 (Done)
Old 07-13-2013, 05:07 AM
rzbill's Avatar
rzbill rzbill is offline
If you strike out looking for soft 426-5 rivets, I have a stock of aluminum AN threaded hardware, including #8 flatheads.
Bill Pendergrass
ME/AE '82
