07-12-2013, 03:44 AM
Engine power settings with BA prop
I am using a Superior Engine that Carlus Gann of Gann Aviations let me help assemble, with a superior cold air sump. He had the engine parts balanced, ported and matched. The engine will likely be a very strong IO360.. If it produced more than 180 hp I figure that I should probably use the restrictions imposed by Hartzell on the blended Airfoil prop 72". That being stated the restrictions are no continuous above 24 in Mp and 2350 to 2550 RPM.
During take off after using max power what settings do you use for climb and when do you go to those settings?
Called hartzell and they said that since we would probably a smoother engine than a stock Lycoming it might not be a problem but they have only tested certified IO 360's. no superior or ECI engines or any other experimental kit engine manufacture.
When I used to fly CS props I'd reduce to 25 square slowly about 500 AGL and use that setting until I got to cruise alt. but this is not going to work if I impose restrictions that Hartzell recommends for engines developing more than 180 hp.
What do you use?
Jack
Smilin' Jack & Anita Hunt
N507H RV7, KJZP Jasper, GA
EAA690
APRS/ WB4JKY
Retired Corporate Pilot CFI-AI, MEL
CE500, LRJT, HS25, C650, SBJT, CL60
Hunt Aviation, LLC.
Pilot Service, IPC's Biennials.
Comm Glider
07-12-2013, 05:58 AM
Unless you upped the compression or are running some crazy advance ignition I'd treat it as a certified engine.
Good luck with that first flight. Carlus builds some good engines.
Sid Lambert
RV-7 Sold
RV-4 - Flying - O-320 Fixed Pitch - Red over Yellow
07-12-2013, 06:51 AM
Originally Posted by Smilin' Jack
...When I used to fly CS props I'd reduce to 25 square slowly about 500 AGL and use that setting until I got to cruise alt....
What do you use?
Jack
Assuming cross country flight, I run WOT from TO to letdown. The prop gets pulled back to 25-2600 about 500 AGL, and 2350-2400 at top of climb. Since I live out west, TOC is almost always 7500 or higher.
200HP/BA.
Michael Robinson
______________
Harmon Rocket II -SDS EFI
RV-8 - SDS CPI
1940 Taylorcraft BL-65
1984 L39C
07-12-2013, 08:31 AM
Michael,
Which blades do you have as I think the newer style has different restrictions for 200HP?
07-12-2013, 02:26 PM
If you are suggesting it might be a healthy 180HP, then it sounds to me like standard compressions, and in that case there is no limits for the new BA series props that I am aware of.
In which case, WOT/2700 and lean in the climb to a target EGT. Only drop some RPM for noise abatement and once through 1500AGL go back to 2700.
In the cruise, LOP ops is healthier, for Aero's and any ops requiring full range of throttle use and wanting every pony you can ROP ops are preferred.
Any questions please go ahead, but first do some research on what the actual limitations are, not perceived or hangar talk ones.
They are nice props BTW.
______________________________
David Brown
DYNON Authorised Dealer and Installer
The two best investments you can make, by any financial test, an EMS and APS!
07-12-2013, 02:56 PM
Originally Posted by Brantel
Michael,
There's two types of BA blades?
...I'll check the logs and see what I have for part numbers.
Michael Robinson
______________
RV-8 - SDS CPI
1984 L39C
07-13-2013, 08:32 AM
ECi IO-370
I emailed Hartzell to ask about restrictions with this prop and the ECi IO-370. They gave me the same restriction that's been posted above: Continuous operation is prohibited above 24? manifold pressure between 2350-2550 RPM.
Paul
CFI (with a LODA. PM me for transition training)
RV-7- flying since 2009 with a Subie, flying since Aug 2013 with a ECi Titan IO-370
1974 Bonanza V35B because n+1
2020 VAF dues paid! (recurring monthly payment setup)
07-13-2013, 11:52 AM
Thanks for all the replies, I am running the recommended Van's Blended Airfoil prop 72" diameter. Te engine has standard pistons, 8.5 :1 compression
Jack
EAA690
APRS/ WB4JKY
Hunt Aviation, LLC.
Comm Glider
