Old 08-18-2006, 07:19 AM
Robert M's Avatar
Robert M Robert M is offline
Default JB Weld instead of Proseal
Hi gang!
Has anyone used JB Weld instead of Proseal as an adhesive for the foam ribs in the trim tab?
"Pilots: Looking down on people since 1903"
(author unknown)
RV-9, N556RM, O-320, Dual PMags, Catto 3 blade.
FLYING since 2018
Mosquito XEL ready for flight
Old 08-18-2006, 08:38 AM
sf3543 sf3543 is offline
I used JB Weld to bond in metal ribs for my trim tab, and it is holding just fine. I also used JB to fasten the NACA ducts on my RV6 and RV8. On the RV6 they were on for 7 years and 900 hours and looked like brand new...no problems. You need to prepare the surfaces by roughing them up with sand paper and JB will bond really well.
I know this isn't the same as using foam, but it should work fine. Try a test piece if you really have a concern....the foam will probably rip before the JB gives way.
Old 08-18-2006, 08:50 AM
Robert M's Avatar
Thanks sf3543!
I kinda figured it would work. If the foam doesn't like the JB I'll make a pair of metal ribs.
(author unknown)
FLYING since 2018
Old 08-18-2006, 09:04 AM
Mike S's Avatar
Mike S Mike S is offline
Senior Curmudgeon
Default other uses
I plan on using JB weld on my rudder and elevator trailing edge extrusions also.
Mike
Old 08-18-2006, 10:15 AM
RickS RickS is offline
I used the aluminum filled version of JB weld on the trailing edges of the elevators and rudder on my -9. Plus numerous other places like the foam ribs in the trim tab. It seems to work great and as long as the surfaces are cleaned then scuffed it had a very tenacious bond.
Best of luck with your project!
Rik
