You can usually unscrew the electrical connection by hand (the plastic part with the wire), you can then unscrew the lamp assy from the front of the panel holding the nut from behind with your fingers. If it's really tight then this method may not work. I believe they are 1/4".
Walt Aronow, DFW, TX (52F)
EXP Aircraft Services LLC
