Go Back   VAF Forums > RV Firewall Forward Section > Propellers
Old 07-08-2013, 04:33 PM
Sunriver Ken's Avatar
Sunriver Ken Sunriver Ken is offline
Default Prop Guard Tape Substitute?
Apparently the manufacturer holding the PMA for "Prop Guard" is out of business. I have a CS Hartzell that has Prop Guard (really needed in AZ) and would like to replace the tape as it is very worn.
Anyone know where I can buy some Prop Guard or a suitable substitute?
Fly safe,
Ken Day
Independence, OR
RV-9A O-360/CS - SOLD
RV-12 SOLD
AA1C 150HP - FLYING
Old 07-08-2013, 06:15 PM
smokyray's Avatar
smokyray smokyray is offline
Default Roll the tape...
Ken,
I have used several different protective tape types on wood and Catto composite props over the years. Rain is a nemesis here in the SEUSA.
Tennessee propellers sells an awesome substitute that works well. I have used good old aluminum tape (same stuff between your wing and flap) sold at Home Depots aviation dept. Works very well but you want to limit the amount of overlap as it reflects. Or, you could paint the tape black. I have also used plain old electrical tape in a pinch.
V/R
Smokey
Old 07-08-2013, 06:28 PM
g zero g zero is offline
Default Tape
I have used clear 3m tape from the auto parts store . It comes in different colors to patch taillights. I used some other clear 3m stuff but it was too thick , I could feel the prop " cavatate "
Tom
Rv8
N 666 TA
First Flight 2-3-2015 🚀
2017 donation paid
Old 07-18-2013, 01:49 PM
CattoPropellers CattoPropellers is offline
We do sell Leading Edge Kits for 2 and 3 bladed propellers; includes tape, glues, and instructions! Give us a call at 209-754-3553.
Old 07-18-2013, 02:03 PM
brad walton brad walton is offline
Default Elastic paint or sealant?
What about some of the rubbery type spray sealant or paint. Something along the lines of the stuff on TV that seals a screen door in the bottom of a boat; or pickup truck bed liner material; or Krylon has some similar applications? Has anyone tried any of these to see if it would be more chip resistant and could be laid on thin enough? Just thinking out loud.
Old 07-18-2013, 05:12 PM
Neal@F14's Avatar
Neal@F14 Neal@F14 is offline
Spruce is selling 3M polyurethane "prop tape".
http://www.aircraftspruce.com/catalo...?clickkey=4936
I wonder if it's the same tape that Prop Guard used... just without the "activator" liquid?
Neal Howard
Airplaneless once again...
Old 07-19-2013, 11:14 AM
flyboy1963's Avatar
Default beware the specs!
so, this is sold as prop tape, but 3M says it's 'indoor grade industrial anti-abrasion' tape
http://solutions.3m.com/wps/portal/3...be90657JDCX3gl
even though it's in their 'aerospace' catalogue. weird eh?
I have a bunch of clear 3m tape on my canopy rails, flaps etc....and it all turned brittle, yellow, and fell off...except the rock-hard adhesive residue stays behind! ( not sure if it's this stuff, but could be)
what's a guy to do?
by the way, 3m sells an adhesion promoter #94, a 'primer' in little ampule sticks that likely would improve the bond..basically it appears to be a glycol based retarder that softens the adhesive a bit to help it stick in tight corners etc.
perhaps one of these tapes is what we need; where to get it, another question;
and some good install notes;
http://multimedia.3m.com/mws/mediawe...pplication.pdf
Perry Y.
RV-9a - SOLD!....
Lake Country, BC
Old 07-19-2013, 02:01 PM
vfrazier's Avatar
vfrazier vfrazier is offline
This is not listed by 3M as a prop tape, so we can't specifically recommend it for that application. However, it sticks well, is very thin, is very tough, it's cheap, and it won't yellow or leave a residue.
3M paint protection films are listed on this page.
Seriously, this stuff is 10x better than UHMW tape, or other clear tapes for most of our uses. Put it under fairings, or anywhere else that paint is subject to scratches, abrasion, or stone chips.
Vince Frazier
www.f1aircraft.com
F1 Rocket and F4 Raider components
1-888-F1AIRCRAFT (1-888-312-4727)
www.flyboyaccessories.com
RV and Rocket Accessories, Tailwheels, Tools, & More
1-888-8FLYBOY (1-888-835-9269)
F4 Raider - under construction
F1-H Rocket "Crazy Horse" - sold
RV-4 "Chief Pontiac" - sold in 1994, purchased in 2018
Old 07-19-2013, 03:04 PM
Rupester Rupester is offline
Default I installed the prop tape from Spruce ...
...on my Catto 3-blade. It's been flying for almost a year and has worked well. Perfect adhesion and protection, though it has yellowed significantly. Doesn't look great on a white prop.
Terry Ruprecht
RV-9A Tip-up; IO-320 D2A
S. James cowl/plenum
(Dues paid thru Nov '18)
Old 06-04-2014, 02:40 PM
Louise Hose's Avatar
Default Mcfarlane has the stuff
Mcfarlane Aviation Products picked up the STC and has the FAA-PMA approval for Prop Guard Anti-Abrasion Boot (tape). It is available at: http://www.mcfarlaneaviation.com/Pro...5&ID=64949242&
