07-07-2013, 11:07 PM
VAF Moderator / Line Boy
Mystery Picture - Old Ideas? New Ideas?
Does this method of hinging a trim tab look familiar? How about the way the hinge pin is secured?
Guess the airplane! (Hint ? I took this while wandering around an interesting small airport yesterday?wonderful area, but I was flying, so I couldn't try the wine....)
Paul
Paul F. Dye
RV-8 - N188PD - "Valkyrie"
RV-3B - N13PL - "Tsamsiyu"
Dayton Valley Airpark (A34)
http://Ironflight.com
07-08-2013, 12:56 AM
Hmmmm
the vertical surface at the far end of the elevator is suggestive of either an Ercoupe or a Beech 18, or something similar. But the Ercoupe doesn't have a tab that I know of, and the Beech 18 tab doesn't extend all the way to the end like that, and I think the near-side rudder would have to be removed to get the end view you got.
So......maybe these thoughts will trigger a flash of insight by someone else.
As for the airport......guessing based on access to good wines,
Oceano or Santa Ynez, Paso Robles, Healdsburg, or? Parked on grass so my guess is Oceano. You did say "small" which in my mind rules out Napa, Santa Rosa, Santa Maria. I'd rule out Columbia because I haven't found any wine near there that is worthy.
Steve Smith
Aeronautical Engineer
RV-8 N825RV
IO-360 A1A
WW 200RV
"The Magic Carpet"
Hobbs 625
LS6-15/18W sailplane SOLD
bought my old LS6-A back!!
VAF donation Jan 2020
07-08-2013, 05:51 AM
Bellanca Cruisemaster.
Jerre
07-08-2013, 06:30 AM
Yes that technique does look familiar. I did my trim tab the same way. I saw that technique used on a T-18 25 or 30-years ago and copied it on my RV.
Unfortunately I do not know the airplane that your photo shows.
Gary A. Sobek
NC25 RV-6 Flying
3,400+ hours
Where is N157GS
Building RV-8 S/N: 80012
07-08-2013, 08:05 AM
I won't keep folks hanging - it was a ramp queen Lockheed PV-2 sitting in the grass at Sonoma Valley (nice little airport on a Saturday afternoon - a Stearman giving rides, a P-40 being moved to the fuel pumps....).
I just found it interesting to see an old military design with the exact same method of trim tab attachment as we use on the RV's - good design ideas are always good design ideas and persist - especially when they are simple.
Paul F. Dye
07-08-2013, 09:11 AM
Sanoma Valley is 15 minutes from KCCR! Give me a shout next time you're in the area. I'm always looking for somewhere to fly my 3.
Rob Holmes
www.myrv3.com
N59LG
The minimum number of planes one should own is one. The correct number is n+1, where n is the number of planes currently owned. This equation may also be re-written as s-1, where s is the number of planes owned that would result in separation from your partner.
- Veluminati
07-08-2013, 09:12 AM
Senior Curmudgeon
Cameron Park is waiting for you
Mike Starkey
VAF 909
Rv-10, N210LM.
Flying as of 12/4/2010
Phase 1 done, 2/4/2011
07-08-2013, 12:04 PM
. . . like this one:
sourced from:
https://en.wikipedia.org/wiki/File:L..._PV-2_NMNA.jpg
I didn't recognize the aircraft by name, so I had to look it up. Maybe this saves someone else a similar search.
Stephen
Stephen & Tyson Humphrey
father-son team building new lives and an RV-9
VAF Donors: 2008 to 2014 * Friends of the RV-1
07-08-2013, 12:18 PM
But in a condition more like this - I think this is the one Paul saw...
Gil Alexander
RV-6A N61GX - finally flying
Grumman Tiger N12GA - flying
07-08-2013, 04:03 PM
It's a Lodestall...........
"I add a little excitement, a little spice to your lives, and all you do is complain!" - Q
Donated in 2020
Reason: spalling
