Old 08-17-2006, 12:55 PM
dicel87's Avatar
dicel87 dicel87 is offline
Default Fuel Tanks
As I continue to "lurk" around this great forum and dream of building a plane, it seems that there are always lots of questions/concerns about constructing the fuel tanks.
So after looking at the pictures of the RANS S-19 one night (from the RV-12 discussion thread) I wondered why is it that the RV series would not have a ready built fuel cell that is dropped into the wing tank as well? Too much modification of wing ribs? Capacity? Reliability? LSA vs non-LSA issue?
thanks for a great source of info!
Scott
Old 08-17-2006, 03:14 PM
Finley Atherton Finley Atherton is offline
If you want to end up being able to consider yourself a "real" builder you must make the tanks. Using Proseal is a "character building" exercise.
Fin
9A Australia
Old 08-18-2006, 07:18 PM
Roadster Roadster is offline
Van's sells pre-built fuel tanks for the RV-9/9A model...
http://www.vansaircraft.com/cgi-bin/...uct=fuel-tanks
RV-10 empennage (h-stab in progress)
My KitLog Pro Website
Old 08-18-2006, 07:50 PM
Van's answer might be weight. Probably cost too. A drop in fuel tank mounted inside the wing has to weigh more than Van's approach, which is simply sealing off the wing structure and filling it with fuel.
I'd estimate at least a 10 lb weight savings from Van's method. Getting a 10 pound weight savings is a big deal.
Kyle Boatright
Marietta, GA
2001 RV-6 N46KB
2019(?) RV-10
Old 08-18-2006, 08:14 PM
dan's Avatar
dan dan is offline
http://www.evansaviationproducts.com/
Dan Checkoway RV-7
Old 08-18-2006, 08:37 PM
Default The (partial) wet wing design is very efficient
It's a very efficient design. Most people building an RV would rather work through the learning experience and not compromise the "Total Performance" objective promised by Van's Aircraft. Quickbuilt kits have the tank structure completed so it is really easy to install a few items and close them - leaks still occur but usually they are not to hard to deal with.
Bob Axsom
Old 08-19-2006, 09:57 AM
dicel87's Avatar
Thanks for the expert feedback. Guess this falls under the "Don't mess with a proven design" category of questions!
