Old 08-17-2006, 11:17 AM
szicree szicree is offline
Question Alodine Resistance?
Can anybody tell me if a alodined aluminum is an okay conductor?
Steve Zicree
Fullerton, Ca. w/beautiful 2.5 year old son
RV-4 99% built and sold
Rag and tube project well under way
paid =VAF= dues through June 2013
Old 08-17-2006, 12:26 PM
DGlaeser DGlaeser is offline
Default Alodine
Everything I've ever read says to clean the surface down to bare aluminum for electrical contacts. Alodine oxydized the surface, and I believe that coating is a poor conductor.
I've put some local grounds (wingtip lights, landing lights) on the spar near the wingtip. After cleaning and mounting the connection, I coated it with Goop for protection.
Dennis Glaeser CFII
Rochester Hills, MI
RV-7A - Eggenfellner H6, GRT Sport ES, EIS4000, 300XL, SL30, TT Gemini, PMA6000, AK950L, GT320,
uAvionixEcho ADSB in/out with GRT Safe Fly GPS
Old 08-17-2006, 03:00 PM
mlw450802's Avatar
mlw450802 mlw450802 is offline
That's a good question. I know that anodized aluminum is pretty lousy. I have several loose alodined parts at home and I'll check to see later.
-mike
Michael L Wilson
Resuming building after a 4ish year hiatus! (life got in the way)
N194MW (reserved) RV9A SB
VAF# 148
Payson, AZ
Old 08-17-2006, 07:53 PM
mlw450802's Avatar
OK, I just put away the DMM and it would appear that the alodine surface is non conductive but quite thin. Light pressure from the probes showed an open circuit but increasing the pressure slightly would push through and show conductivity. The darker the alodine, the more pressure seemed to be required to break through.
This was just qualitative science here- no actual force measurements.
The anodized spar, however, was an insulator regardless of probe pressure.
-mike
Michael L Wilson
VAF# 148
Payson, AZ
Old 08-17-2006, 08:01 PM
RV8RIVETER's Avatar
RV8RIVETER RV8RIVETER is offline
Default IS CONDUCTIVE
Yes, Alodine converted aluminium is conductive. It does not oxidize in a true sense,(which anodizing does) but a chromate conversion process of growing a chromate oxide on the base metal. This chromic oxide layer is conductive.
Of course I am talking about the typical Alodine that has been in use for some time. The newer Alodine formulations, 5700, 2600 ect are chromium free.These newer ones, I do not know.
For more, less technical info:
http://www.eaa1000.av.org/technicl/c...on/alodine.htm
Wade Lively
-8, Flying!
N100WL
IO-360A3B6D, WW 200RV
