  #21
Old 07-02-2013, 02:45 PM
E. D. Eliot E. D. Eliot is offline
Default Complete 'retro' kit?
I'm about 5 years from needing your kit because I'm broke but will you be offering a complete RV-12/Rotax retro kit some time in the future. Sounds like a really good idea to me - and economical too in the long run. Thanks for alerting us to this up grade.
Building finally
Old 07-02-2013, 04:15 PM
Aircraft Specialty Aircraft Specialty is offline
Yes....
We are currently just starting an RV-12 build. We will be offering a complete retro kit.
But, for those who want them now, we can build the hoses to custom measurements.
Have a great day,
Steve
Steve Tschurwald- Aircraft Specialty LLC (Your source for Custom Parts for Experimental Aircraft), AS FLIGHTLINES (Joint Venture with TS Flightlines)
aircraftspecialty@gmail.com
www.aircraftspecialty.com
www.asflightlines.com
Old 07-02-2013, 07:32 PM
Jetguy's Avatar
Jetguy Jetguy is offline
Question Those hoses are cool!
I have a few questions for Tom about the hoses for the Rotax.
On the last pic with the fuel block removed is there a restriction in the fuel return line?
What would the total cost be for that mod in that same pic(compete Rotax retrofit)?
Will you have a booth at OSH with a few of these Rotax hoses there?
John
RV12 N1212K
Flying Since June 2010
1020 Hours as of 9/30/2017
Johnrv12@icloud.com
RV14 Wing, arrived and building at Rdog's new Hanger at 16X
S/N 140014
Old 07-02-2013, 07:43 PM
Dvalcik's Avatar
Dvalcik Dvalcik is offline
Default same ?s
John you beat me to the same questions
Plus can we order at Oshkosh?
David
EAA 1250 KPTW
Royersford, PA
david@rv12pilot.com
2020 VAF Supporter
RV12 #568 EAB
* Started 9/30/2011
* 1st flight 8/30/12
http://www.rv12pilot.com
Old 07-02-2013, 08:13 PM
John and David,
Right now I probably will not be at OSH. But--if you'll email me, I'll tell you anything you want! The pic that Steve posted here is of a RV12, with a slightly modified fuel pump to accomadate the AN hose ends. The original Rotax hoses are rubber, with either low pressure crimp bands. Some applications of the same engine are using hose clamps. Mine are my standard stainless teflon hose, with stainless hose ends. An AN tee, and an AN cross are used in these assemblies.
I basically copied the original hoses, so everything fits.
My email is tsflightlines@gmail.com
Tom
Ridgeland, SC
Old 07-02-2013, 08:38 PM
OH yeah---that hose package is on John Jones' beautiful RV12 in Fort Worth. John was nice enough to email me the installed pics. I'm pretty sure if some of you are in the Ft Worth area, he would not mind at all if you looked at his installation.
Tom
Ridgeland, SC
Old 07-03-2013, 08:55 AM
dick seiders dick seiders is offline
Scott, don't know the answer to your question on the Facet fuel pump. Couldn't find anything in forum search either. However the elec. pp. puts out about 1.2lbs pressure and I suspect that would be sufficient to help with a more controlled off field/on field landing as the engine would be developing power and landings are usually accomplished with a closed throttle (given sufficient altitude and suitability of landing area). 3.8lbs is normal with a working mechanical fuel pump, but 1.2 may be sufficient to fly above stall speed until a suitable landing area is found. It would certainly be the first thing to try. It's a good question. Hopefully someone out there has a more definitive answer.
Dick Seiders 120093
Old 07-03-2013, 05:50 PM
NASA515 NASA515 is offline
I don't understand - the POH Checklist calls for Fuel Pressure before Start as 'Normal", which is - I believe 2.2 psi. My boost pump puts out about 2.7 psi before I turn the Start key (I have a separate Fuel Pump Switch - but pulling the pump fuse accomplishes the same sort of check.)
After engine start, the fuel pressure is more like in the 5.7 - 5.9 psi range.
Bob Bogash
N737G
Old 07-03-2013, 06:19 PM
Jetguy's Avatar
Question
Bob Bogash
N737G
IMHO "Normal" means anything more than zero. At this point you are just verifying that the electric fuel pump is working by it showing "some pressure". Then after start the engine driven fuel pump starts working and then the fuel pressure comes up in the green or normal range on the Skyview.
John
RV12 N1212K
Johnrv12@icloud.com
S/N 140014
Old 07-03-2013, 08:15 PM
OK - the question is -- will the 2.7 psi from the elec boost pump run the engine normally with an INOP engine driven pump???
Bob Bogash
N737G
