Go Back   VAF Forums > The Never Ending Debate Section > Tip up canopy vs. Sliding canopy
  #11
Old 06-29-2013, 04:26 AM
High_Flyer's Avatar
High_Flyer High_Flyer is offline
Default Tip up
Tip-up, because I'm buliding my -7 to fly, not to taxi with the canopy open
Yes it can be a bit on the warm side during the limited time spent on the ground, but once airborne the unrestricted visibility of the tip-up is fantastic.
RV7 (F-PRVZ), Tip Up, Aerosport IO-375, Dynon Skyview, VP-X, Day VFR.
Flying since June 2017.
Old 06-29-2013, 09:32 AM
Neal@F14's Avatar
Neal@F14 Neal@F14 is offline
Originally Posted by FORANE View Post
... I would consider a plane with wood prop if the price allowed for the replacement prop I know I would eventually be installing.
Do these models have a tendency to be nose heavy?
Actually the -6/-7 models with wood or composite fixed pitch props, and if they also have an O-320 engine, tend to get tail heavy instead.
Neal Howard
Airplaneless once again...
Old 06-29-2013, 10:36 AM
rzbill's Avatar
rzbill rzbill is offline
The plane will be used all weather.
If that is true, then there really is no choice. Slider.
I speak as a tip-up driver that still has leaks and wants to fly IFR. If you build by the plans, a tip-up MUST leak at the hinges. My hinges no longer leak due to mods I have done but the misfit I have at the left and right curves remains a small leak path. It is small but I will not be satisfied until it is zero. I did a 180 on my last weather flight because of water coming in. Very unnerving when all your bacon is riding on electronics. It was hard to hold my composure, get out of the rain and get on the ground.
On the flip side, I have ridden in multiple sliders. They all rattled and blew air on your neck and I felt claustrophobic so I am not an automatic convert. I like tipups better except for the d***ed leak paths.
Bill Pendergrass
ME/AE '82
Old 06-29-2013, 06:16 PM
Jesse's Avatar
Jesse Jesse is offline
I've never flown in a tip up, but I love the -9A slider in the Florida heat. Love to taxi with the canopy back. I'm used to the -10, so my visibility is already better than I am used to.
Jesse Saint
Old 06-29-2013, 06:47 PM
Ironflight's Avatar
VAF Moderator / Line Boy
As someone who didn't choose a side-by-side (I married into one) and came out of a Grumman Yankee before entering the RV world, I was a bit worried about the tip-up in the Texas heat. I didn't need to - I have felt that I get as much cool air in the tip-up in the rest position as I did in the Yankee with the slider open on the ground. Granted, in the real heat, NEITHER is going to be truly comfortable - but subjectively, having experienced both styles for a lot of hours in extreme heat, I feel that they are about equal for ventilation.
Visibility wise, as has been said, the Tip-up has less stuff in your way.
Having done two panel upgrades on the -6, I can say that it is awfully nice to get the canopy out of the way - but I still end up on my back underneath in the little cave....
Paul F. Dye
RV-8 - N188PD - "Valkyrie"
RV-3B - N13PL - "Tsamsiyu"
Dayton Valley Airpark (A34)
http://Ironflight.com
Old 06-29-2013, 07:10 PM
n5lp's Avatar
n5lp n5lp is offline
fugio ergo sum
Default Aaaagh, again
I think it is kind of like handed down wisdom for many other aviation things. Stories are repeated by those with no first hand experience.
The tip-up RV-6/7s are not uncomfortable on the ground in hot temperatures. With the canopy propped open they are fine. I have about fourteen years of experience in a very hot climate to support this. The sliders are also fine for ventilation. The tip-up drawbacks on the ground are that you have to be aware of winds slamming the canopy closed and you can't taxi in with your arm sticking out, although I can't figure out how you can do that anyway, as you need one hand on the throttle and the other holding the stick back. That is it for ground drawbacks. There are great advantages like an unobstructed view in the air.
RV-10s can be uncomfortable on the ground in warm weather, based on experience, but no one seems to talk about that. The little side-by-side two seaters are fine for ventilation with either canopy configuration.
Larry Pardue
Carlsbad, NM
RV-6 N441LP Flying
Old 06-29-2013, 07:17 PM
Mel's Avatar
Mel Mel is offline
20 plus years experience in Texas heat. No regrets!
RV-6 Flying since 1993 (sold)
<rvmel(at)icloud.com>
Old 06-29-2013, 07:19 PM
Brantel's Avatar
Brantel Brantel is offline
It can get warm sometimes. I use the partially locked open method to help. Not as good as a slider with the arm over the side but good enough.
Brantel (Brian Chesteen),
RV-7/TU, #72823, N159SB
Track N159SB (KK4LIF)
Old 06-29-2013, 07:43 PM
FORANE's Avatar
FORANE FORANE is offline
This is concerning. I was leaning toward tip up. Yes definitely true that intended use will be all weather IFR with ice as about the only exception.
Do the tip ups suffer from water coming in on the ground if tied down without a cover also?
Old 06-29-2013, 08:23 PM
n5lp's Avatar
fugio ergo sum
It is a possibility that is easily remedied with a bit of electrical tape.
Larry Pardue
Carlsbad, NM
RV-6 N441LP Flying
