Old 06-27-2013, 07:41 AM
paulevans's Avatar
paulevans paulevans is offline
Default Securing RV-7 withouth Tie Down Brackets/Bolts
Need to secure my RV7 and do not have tie down brackets or bolts under wings. Is there a proven solution already out there? Are there any canopy covers that include a nylon loop or hook to tie down to?
Old 06-27-2013, 08:30 AM
Guy Prevost's Avatar
Guy Prevost Guy Prevost is offline
Welcome to VAF!
It would take serious effort to not put the brackets in the wings, they back up the aileron bellcranks. If they are not tapped, it is a 5 minute job to do so. Are you sure they are not in there? I don't generally fly with my tie down rings in place, but it's not a problem to screw them in after landing away from the hangar. I believe using the stock brackets is really the best method. I know you get wind in Phoenix! The canopy cover method would basically secure your plane by the canopy.
To answer your actual question, I don't know of any covers that include tiedowns.
Best,
Guy
Guy Prevost
Albuquerque, NM
RV-8a Built, Enjoyed, Sold
Two Kids: Built, Enjoying
RV-10, Bought, Rebuilt, Enjoying
Build / First Flight Video: http://www.youtube.com/watch?v=8f9HXzZT1dE
Build Log: http://websites.expercraft.com/geprevo/
Arguing on the internet is like having a competition to see who can hit a brick wall the hardest. You may win, but you're still an idiot.
Old 06-27-2013, 08:52 AM
Sig600 Sig600 is offline
What Guy said, did you buy or build? If you bought it, you should see holes in the wings at the outward most inspection panel.
Here's some trick tie down rings you can screw in.
http://www.cleavelandtool.com/Stainl.../#.UcxRfXy9KK0
Next?, TBD
IAR-823, SOLD
RV-8, SOLD
RV-7, SOLD
Old 06-27-2013, 11:57 AM
rzbill's Avatar
rzbill rzbill is offline
As was already said, but I think needs further emphasis, those two extrusions are structurally critical to the aileron control brackets.
Please confirm that they exist on your craft before further flight.
Bill Pendergrass
ME/AE '82
Old 06-27-2013, 01:16 PM
larrynew's Avatar
larrynew larrynew is offline
Here's where you will find the threaded holes for the tiedown rings. Just forward of the third outboard inspection panel. As others have said, it's a part of the aileron bellcrank bracket assembly so it's important.
Larry New
RV-7A - Flying 900+ hrs
RV-10 - Flying 2.9 hrs
48 States in 7 Days!
VAF Paid - Annual Autodraft
Old 06-27-2013, 01:24 PM
rv7boy's Avatar
rv7boy rv7boy is offline
Forum Peruser
Or some standard tie down rings from the same source (Cleaveland):
http://www.cleavelandtool.com/Forged.../#.UcyROfnVA1I
Don Hull
RV-7 Wings
KDCU Pryor Field
Pilots'n Paws Pilot
Old 06-27-2013, 01:56 PM
rzbill's Avatar
For the sake of argument, lets assume the original builder DID put the W-731 tiedown bars in, but decided not to drill the skin or tap the bar.
I was looking at Larry's drawing and realized it might not be trivial to confirm the existence of the bars (like having to take off the tanks, ugh).
My memory says there was a #30 or #40 prepunch hole in the skin on my 2005 vintage kit. We had to enlarge it. If it is there on the OPs craft, one could fish a stiff wire in there to feel if the W-731 was in place.
If it is, one could use a "Roto-cut" bit with pilot to enlarge the hole without touching the W-731. Tapping the thread afterwards would then be easy.
Rotacut
An alternate way to confirm existence might be to remove the AN3's from the aileron brackets and inspect the holes. If you can see 3 thicknesses of material before the nutplate threads, good to go. Ref dwg 15.
Last of course is to remove the tank....yuk.
Bill Pendergrass
ME/AE '82
