Two critical temperatures apply:
Flash Point - The temperature at which a liquid will give off vapors that will burn with an ignition source.
Autoignition temperature - No ignition source needed.
The Flash on most motor oils that I can find data on is over 400 degrees F.
Autoignition temps are harder to find, but seem to be in the over 800 degree range.
Dave Durakovich
CFIG, AGI, COMM SEL, VAF# 133
RV-4, N666PR, Finished (Well, at least flying)!
RV-6 - Adopted an orphan!
Detroit, MI
"If you think you can do a thing or think you can't do a thing, you're right."
Henry Ford
