06-22-2013, 04:38 PM
Cutouts in sides of cylinder baffles: Covered or uncovered? (photos)
I've never payed any attention to the small oval cutouts in the aluminum baffle walls near cylinders #3 and #4. Yesterday I realized that one of them is open, and the other is covered by rubber baffling material. See the photos below. Can anybody tell me if these are intended to be open or covered? What is the purpose of these openings? Also, I'm curious what the function of the angle aluminum bar is just below the openings. Is it just a stiffener, or is it supposed to direct airflow as it exits these holes (assuming they're designed to be uncovered and open)?
Karl, Goodyear, Arizona (KGYR) ATP, CFII
RV-14A, Flying
Extra 330LX, Flying
RV-8, Sold
RV-7, Sold
Bearhawk 4-Place, Sold
=VAF= donor 2020
06-22-2013, 04:43 PM
Looks like a relief for the top plug wires. I'd fill them.
Sid Lambert
RV-7 Sold
RV-4 - Flying - O-320 Fixed Pitch - Red over Yellow
06-22-2013, 04:47 PM
These cutouts are used when removing #3 and #4 top Spark plugs.. Put the socket over the plug, then insert a 3/8" extention through the cutout and into the socket.
Most everyone puts either the baffling material over them from the inside, or a screw with washers and a nut, to cover the cutouts....
Fred Stucklen
wstucklen1@cox.net
RV-7A N924RV Flying (1825 Hrs & counting)
RV-6A N926RV 875 Hrs (Sold)
RV-6A N925RV 2008 Hrs (Sold)
06-22-2013, 04:49 PM
Baffle instructions say...
I think the plans call for a flat head screw, two large tinnerman washers (one on each side of the baffle), and a lock nut to cover these...
Melinda Harrill
Flying my RV-7!
Barrett Precision Engine - Superior IO-360 with AFP FI
Garmin Panel - All touchscreens
06-22-2013, 04:50 PM
For wrench access.
The cutouts are to allow access of a 3/8 socket extension to pass through when removing or installing spark plugs. There are some #10 dimpled washers and #10 screws and nuts provided with the baffle kit to cover the openings. I also cut a washer made from the baffle material used with the dimpled washers to get a good seal on the baffle.
Dream it, Build it, Fly it
Paul Merems (EAA Tech Counselor, EAA Sheetmetal Workshop Instructor/Volunteer 12 yrs)
ExperimentalAero- HANGAR BANNERS
www.experimentalaero.com
RV-7A (Flying since 2010)/RV-4 (sold 1990)
Tucson, Arizona 85749
06-22-2013, 06:48 PM
Okay thanks guys. I've never had a problem getting to top plugs on #3 and #4, so never used these openings. I'll close them up as described here.
RV-14A, Flying
Extra 330LX, Flying
RV-8, Sold
RV-7, Sold
=VAF= donor 2020
06-25-2013, 07:53 AM
I also followed the instructions and used the two tinnerman washers, but they don't cover the entire hole so I put some hightemp RTV all around them .
