View Poll Results: I wear a parachute when I'm doing aerobatics:
Always 5 15.63%
Almost Always 2 6.25%
Only if I'm doing more than a couple maneuvers 6 18.75%
Rarely 5 15.63%
Never 14 43.75%
Voters: 32. You may not vote on this poll
Old 08-15-2006, 09:41 PM
BrickPilot BrickPilot is offline
Question Parachutes?
Just curious. Please answer the above. Also, option #2 should be "ALMOST ALWAYS". (I fat fingered it and I cannot delete the poll entry).
Jeffrey Klug
Bearhawk #1053
Shop under construction
Lehi, UT
Old 08-16-2006, 02:51 AM
unqualified unfluencer
Fix poll option #2 for you, Jeffrey <g>.
b,
dr
Doug Reeves (your host)
Old 08-16-2006, 05:54 AM
pierre smith's Avatar
Default Nope
Hi Jeffrey,
FYI, this discussion has been done before and may be archived but the general consensus was that since you cannot open an RV 6 or 7 in flight, a parachute is pointless.
Pierre Smith
RV-10, 510 TT
Air Tractor 402 PT-6-20 Sold
Louisville, Ga
Patrick Kenny, EAA 275132
Dues gladly paid!
Old 08-16-2006, 08:39 AM
Originally Posted by pierre smith
Hi Jeffrey,
Typical newbie mistake - not searching the threads. I did hear that on some of the RV models, the canopy cannot be opened in flight, but also read that some builders install quick-release pins. Not sure if that's viable on all models / configurations, but I would guess that some folks have resolved it to their satisfaction.
Jeffrey Klug
Bearhawk #1053
Lehi, UT
Old 08-16-2006, 09:16 AM
praterdj praterdj is offline
I think I remember Paul Dye stating he had some type of quick release set up. Hope he never has to use it.
I know the canopy material is totally different than car glass but I was told that a spring loaded center punch would shatter a car glass,,,,would it have any affect on a canopy?
Donald Prater
Formerly 52F now Arkansas...Go Hogs!
RV-8 Empennage Underway
N-284DP (Reserved)
Old 08-16-2006, 09:52 AM
MXpilot1 MXpilot1 is offline
I assume it is the tip ups that will not open in flight. I believe I could open my slider and so I usually wear a chute when doing aerobatics. Actually getting out might be a challenge though.
Old 08-16-2006, 10:40 AM
kevinh's Avatar
kevinh kevinh is offline
I know my slider would open. If the handle doesn't do it I have two pull pins attached to four inches of webbing.
But based on lots of flying RVs, 10% that do acro (just guessing), and no bailouts - I think the risk is low.
I still wear the chute though (have to have it anyway for passengers, might as well use it when solo). At the very least, it saves putting the seat cushions back in.
-kevinh, Track my RV-7A, flying, alas, sold in 2013 after 450ish hours. (I'm now building something different)
Old 08-16-2006, 01:32 PM
Mel's Avatar
Mel Mel is offline
If the tip-up canopy is installed as originally intended, it may be jettisonned in flight.
RV-6 Flying since 1993 (sold)
<rvmel(at)icloud.com>
Old 08-16-2006, 01:42 PM
I was going through some old RVator magazines and they said the canopy on the 4 is designed so that it will tear away from the rivets. They mentioned a couple of occasions where this had been done and it did not impact the airplane when exiting.
Donald Prater
N-284DP (Reserved)
Old 08-16-2006, 01:53 PM
mdredmond mdredmond is offline
...because when you're jumping out of your airplane you're really worried about whether the jettisoned canopy hits the tail? LOL.
Matt Redmond
Denton, TX (KDTO) - VAF #510
Got the Bug & Wife's Signoff
RV-9 Tip-Up, Empennage & Wing
