Todd----dont slit the firesleeve. IF you have patience (?), you can work the sleeve over the hose end B Nuts. Sometimes necessary to use your air compressor and a blow gun to expand the sleeve to make it alittle easier. Not an impossible task, and no need to make a new hose.
Be sure to seal the ends of the firesleeve.
Tom
Ridgeland, SC
