Old 06-17-2013, 04:39 PM
chazking's Avatar
chazking chazking is offline
Default RSA 5 vs RSA 10 on IO540
Which is the better fuel servo for an IO 540? RSA 5 (FM200) or RSA 10 (FM300)? I'm told the 540 "breaths" better with the 10 (FM300) & that makes the 540 "more efficient." Where does the truth lie?
Ch?z King
Old 07-12-2013, 05:31 PM
Toobuilder's Avatar
Since the RSA-10 and -5 are both found on 540's and 360's, I've often wondered this as well.
Michael Robinson
______________
Harmon Rocket II -SDS EFI
RV-8 - SDS CPI
1940 Taylorcraft BL-65
1984 L39C
Old 07-12-2013, 05:58 PM
rocketbob's Avatar
There is less of a pressure drop across the venturi of the -10 than the -5. That said to take advantage of the additional airflow capability you should go with the cold air sump if you want to go with a -10. The -10 will not bolt to a stock 540 sump.
Bob Japundza CFI A&PIA
N678X F1 Rocket, under const.
N8155F C150 flying
Not a thing I own is stock.
