Old 06-17-2013, 10:29 AM
newrv-4 newrv-4 is offline
Default Prop Extension Dimensions for O-320
Does anyone have the dimensions for a 4" or 2.5" prop extension for an O-320. A machinist friend of mine offered to construct one if I found the plans.
Old 06-17-2013, 03:12 PM
g zero g zero is offline
Default Spacer
You can buy spacers from a 172 . Cheap and plentiful , I shaved one down for another project and added some chromemoly drive lugs . Check with Flagler Air Exchange or Wentworth .
Tom
Rv8
N 666 TA
First Flight 2-3-2015 🚀
2017 donation paid
Old 06-17-2013, 03:17 PM
deek deek is offline
I'm new here too, but I strongly suggest you not do this. I've been involved in homebuilts since 1980 and have seen at least 5 people attempt to build their own prop extension with 4 of them resulting in spectacularly bad results. Saber is where you need to go for an extension that won't fail. There are so many issues with building a reliable prop extension/bushing system!
'83 LongEZ - N888EZ 3,671 hours
'89 LimoEZ - N26EZ 686 hours (sold)
A couple of Glasairs and a Lancair 320...
Next: a RV14 need something to build
Old 06-17-2013, 03:27 PM
Mel's Avatar
Mel Mel is offline
Gotta go along with DEEK on this. Prop extensions are nothing to mess around with.
I've run Saber extensions on several aircraft since the early '90s, and have to say, they are a work of art.
RV-6 Flying since 1993 (sold)
<rvmel(at)icloud.com>
