Originally Posted by brian257
... Are you saying that is is supposed to be from 233-240 ohms at 0 PSI or are you saying that it is supposed to read 240 ohms at 0 PSI and 33 ohms at whatever the high end of the pressure range is?
The latter: 240 ohms at 0 PSI. At the upper limit of the rated pressure the resistance decreases to 33 ohms.
Here's a group of pressure senders (not necessarily for an RV) and it will confirm that.
N.B. This explains why an "open" or disconnected sender produces a pegged gauge.
